here is an answer to all those "where to get solid engine mounts" posts
Old Mar 9, 2008 | 05:36 PM
  #76
Ghost 5.9's Avatar
Default Re: (tricura)
i would love a set for the bisi/evolution h2b kit asap if possible
Old Mar 9, 2008 | 07:56 PM
  #77
Elwuudz's Avatar
Default Re: here is an answer to all those "where to get solid engine mounts" posts (Turbo-charged)
what is the advantage of running a solid mount with the absence of the poly bushing vs a mount such as hasports with very stiff poly inserts?
purely drag applications fo launching?
Old Mar 10, 2008 | 05:11 AM
  #78
ud180's Avatar
I heard they have them for the EF's for the B-series. Does anyone have them yet? Where can I get a set?
Old Mar 10, 2008 | 06:43 AM
  #79
onefastegg's Avatar
Default Re: (ud180)
wootparts.com
Old Mar 10, 2008 | 08:27 AM
  #80
FourBangerIndustries's Avatar
Default Re: here is an answer to all those "where to get solid engine mounts" posts (Elwuudz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elwuudz &raquo;</TD></TR><TR><TD CLASS="quote">what is the advantage of running a solid mount with the absence of the poly bushing vs a mount such as hasports with very stiff poly inserts?
purely drag applications fo launching? </TD></TR></TABLE>
the solid mounts do not allow any engine movement, which means your getting more power to the ground and putting less stress on your drivetrain components. even with extremely stiff poly bushings, there is still room for movement/flex. the solid mounts will also increase throttle and shifting response. i think they would be great for drag/road racing where all of the above would be beneficial.
Old Mar 10, 2008 | 04:38 PM
  #81
d15bfi's Avatar
Default Re: here is an answer to all those "where to get solid engine mounts" posts (FourBangerIndustries)
so your saying i have a 93 ex coupe with a 3 post timing belt side D series. I can run the EG B series solid mounts? No mods needed?
Old Mar 11, 2008 | 08:38 AM
  #82
Default Re: here is an answer to all those "where to get solid engine mounts" posts (d15bfi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15bfi &raquo;</TD></TR><TR><TD CLASS="quote">so your saying i have a 93 ex coupe with a 3 post timing belt side D series. I can run the EG B series solid mounts? No mods needed?</TD></TR></TABLE>
you bet your *** you can!!!
Old Mar 11, 2008 | 04:24 PM
  #83
d15bfi's Avatar
SICK!!! Makes things alot easier
fuzzysig
Acura TSX
Jun 6, 2017 09:31 AM
jcayo11
Acura TL, RL & ZDX
Mar 28, 2010 01:51 AM
Poroshok
Jul 16, 2007 07:12 PM
mingchi69
Feb 20, 2004 08:08 PM
