Flow Control Valve
Old Feb 18, 2012 | 07:58 AM
gc8dc95's Avatar
Default Flow Control Valve
Just wanted some insight on the flow control valve for the clutch line. I will be running a twin disk this year and read about it.
How many of you guys use it? Is it necessary?
Old Feb 18, 2012 | 08:15 AM
cjordan's Avatar
Default Re: Flow Control Valve
i run one, it helps me with staging and helps save heavy shock that occurs when shifting gears... I have a CC twin disk and am running the middle sized pill...
Old Feb 18, 2012 | 08:45 AM
PRO1's Avatar
Ive heard a lot of people burning up ceramic clutches with them works best with a carbon clutch
Old Feb 18, 2012 | 12:48 PM
0554's Avatar
Ditto!
Old Feb 18, 2012 | 01:50 PM
Dynamic Performance Racing's Avatar
This.
We don't run it on our cars and we run a Clutch Masters Twin Disc 725 series. However, we do run a dog box. Might help if set up properly (smallest orifice) and on a stock gearset.
Old Feb 18, 2012 | 04:34 PM
E Town DSM's Avatar
Weve run them on ceramic and carbon clutches as long as you dont get to aggressive with the orfice both will survive pretty well.
Old Feb 19, 2012 | 05:25 AM
gc8dc95's Avatar
I am planning on a stock gearset for now. I have a comp twin.
From what I have read it is mixed reviews on whether to run one or not, so info from people is appreciated.
Old Feb 19, 2012 | 06:47 AM
a267mm's Avatar
i used it on a vr6 6 speed with a clutch master twin disk, clutch only lasted 3 months with out even getting into boost called clutch master and they blamed it on the tune had to buy a rebuild kit they wouldn't cover it under warranty
Old Feb 19, 2012 | 08:40 AM
xtremvw's Avatar
had big clutch issues with CM one as well but heard great things about the Tilton, will try Tilton and see. On the CM valve i had even drilled the holes bigger to stop slipping and still would not work.. I think they need to re do that design..
Old Feb 19, 2012 | 09:33 AM
ExospeedAMcrx's Avatar
We've initially ran the Tilton FCV on our Tilton ceraamic twin and it worked great. We also used the Hydraulic Releasing Bearing after and the whole clutch setup just felt even better with the whole combo. We're using the Tilton Carbon with theTilton HRB and FCV now. The Tilton combos are great, its one of those that you set it and forget it. Never have issues with it.
Old Feb 19, 2012 | 10:01 AM
utahturbosohc's Avatar
I use the Tilton FCV on my single disc set-up, with the medium sized oriface, never had a problem. I street drove the car daily all year, as well as drag racing every weekend.
Old Feb 19, 2012 | 05:32 PM
toddvw's Avatar
ive had the tilton valve on my car for about 2 years with a clutchmasters fx700 twin. middle orifice the whole time and clutch has been fine. i also take the clutch out all the time and sandblast the iron off it.
Old Feb 19, 2012 | 06:35 PM
KStuned's Avatar
We've never used a FCV. Works flawless without it with our Competition Clutch twin disc.
Old Feb 19, 2012 | 07:23 PM
SPOOLINmatt's Avatar
i just use the biggest orifice now. I used the smallest and it seemed way to slow but im sure the trans was liking it though when it was stock lol. Medium should cushion pretty well too.
Old Feb 20, 2012 | 05:43 AM
portenio78's Avatar
x2
Old Feb 21, 2012 | 12:21 PM
hondaracing84's Avatar
I used the tilton FCV with the smallest orifice and was cutting a 1.6 60ft. It was very forgiving on my drive train.
Im switching to the clutch masters FCV because I want to play with the orifice sizes more and change boost levels to see if I can get my 60ft down. And I like the idea that you do not have to break the hydrolic system to change them. I hate bleeding the system.
Old Feb 21, 2012 | 12:39 PM
littlebluecrx's Avatar
of course it works flawless with out it... you also pay attention to transmision assembly and dont abuse parts... the flow control helps people that have a habit of stabing the clutch or droping the clutch get more consitent clutch application... if you are consitent driver and have good habits you wont see the same results as some one who does not. As far as burning up clutches if you have a small bleed and the clutch returns slow yeah I could see issues... but if the pedal is adjusted properly and you use the medium or larger pill it shouldnt affect clutch life at all... it is a must if you want to keep stock trans leaving as long as possible....it's like anything else use it proper and you will see the best results use it wrong and enjoy shity results....
Old Feb 21, 2012 | 02:01 PM
SwappedTURBOegg's Avatar
would one of these work? http://www.grainger.com/Grainger/ING...ol-Valve-6ZC07
Old Feb 22, 2012 | 06:34 AM
Originally Posted by SwappedTURBOegg
operating pressure of 200 psi..... havent dataloged the clutch pressure.." maybe one of the motec user's have :p" , but the tec specs says
Thermoplastic
Glass-reinforced valves provide free flow in 1 direction, controlled flow in opposite direction. Color-coded micrometer and calibrated adjustment ****. Ring lock keeps adjustment from accidentally moving. Panel mount nut included.
Operating temp. range: 0° to 200°F
looks like it is adjustable via **** instead of pill change.... now experimenting with that might burn up clutch if you get the realease set to slow.... might work but might not last in a motorsports enviorment... for the price might be cool to try though....
Old Feb 22, 2012 | 07:42 AM
nonvtecallmotor's Avatar
Thermoplastic
I'm sure that a clutch line is above 200psi. I think its close to what brake pressure is.
Old Feb 22, 2012 | 11:59 AM
FIST321's Avatar
So The fluid control valve is it pretty much just a restrictor?
85mmek9
Mar 21, 2012 01:03 PM
boostedBLUfg2
Apr 3, 2011 08:01 PM
SPOOLINmatt
Oct 5, 2008 08:19 PM
reactiondc2
Mar 5, 2007 07:12 PM
