tilton flow control valve
Old Mar 30, 2011 | 09:45 PM
boostedBLUfg2's Avatar
Default tilton flow control valve
the shop i'm going through recommended i purchase one of these to go along with my build because i had expressed concerns of my transmission grenading in my 8th gen si once i'm hitting 450-500 whp. i looked online but i'm a little confused, does this just engage the clutch a little slower to reduce shock when the clutch engages? have people found it to be worth the $175 or so that it costs?
thansk
Old Mar 30, 2011 | 11:38 PM
xfrankx's Avatar
Default Re: tilton flow control valve
http://www.tiltonracing.com/content....st2&id=436&m=b
google search works well
Old Mar 31, 2011 | 12:05 PM
thanks, that answered exactly what i was asking (sarcasm)
Old Apr 3, 2011 | 08:01 PM
xfrankx's Avatar
thansk
The TB&C flow control valve is designed to reduce shock load to the driveline by allowing the clutch to slip slightly during engagement. Shock load is a result of an abrupt clutch engagement when the crankshaft and input shaft speeds are not precisely matched. The flow control valve is designed to reduce the chance of losing traction when downshifting (road racing, entering pit lane) and/or reduce the chance of damaging driveline components (broken axles, transmissions, etc). This valve can also be used in drag racing applications to reduce shock load to a driveline when launching.
how does that not answer your question? you asked if it engages it slower to reduce shock. it clearly says that right in the discription hahahaha.
85mmek9
Mar 21, 2012 01:03 PM
SPOOLINmatt
Oct 5, 2008 08:19 PM
reactiondc2
Mar 5, 2007 07:12 PM
BrandonClaps
Apr 20, 2003 04:43 PM
