Just threw a CEL code - question.
how about u wait till you ge ta scanner of some sort to let u know what it is why beat your self in the head about that you could be totally wrong... p.s you should have had the check engine like prior to your removal cuz you didn't have it in there either way
I bet you its fine. check the connection, check the oil, and just reset the ECU (remove negative battery cable for 10min or so) and try again. If not hit me up, Ill hook you up with one of my special solenoids with a HT discount.
Ok, had everything unplugged for 10 minutes ish, plugged it all back in, fired up the car, both the CEL and the ABS light went away.. Car is still warming up, but I think everythings fine now!!
SubTitle
10
Oct 18, 2005 09:33 PM
98-0688
Sep 2, 2004 04:56 PM
