Just threw a CEL code - question.
Old Feb 9, 2007 | 10:50 AM
LunchboxZT's Avatar
Default Just threw a CEL code - question.
My car has been sitting in my garage for about 1 month now without being started, I put fuel stabalizer in it before I garaged it.
Last week I took the catback off the car (I still have a test pipe w/ 02 sensor going into the header).
I just started the car today to move it to another spot in the garage and I threw a CEL. I haven't checked it yet, mainly becasuse I don't even plan on driving it for another month or so, but I'm wondering if not having the catback on would throw the CEL? And when I put the new exhaust in everything should be fine right?
Old Feb 9, 2007 | 10:59 AM
walker111's Avatar
Default Re: Just threw a CEL code - question. (LunchboxZT)
If you didnt have the cat on it will more than likely throw a code. No need in putting stabilizer in there if its only a month or two..
Old Feb 9, 2007 | 11:04 AM
LunchboxZT's Avatar
Default Re: Just threw a CEL code - question. (walker111)
Yeah, I didn't put much in - just figured, better safe than sorry. As for the cat, I only have a test pipe, do you think that would make a difference?
Old Feb 9, 2007 | 11:05 AM
walker111's Avatar
Where is your secondary o2?
Old Feb 9, 2007 | 11:14 AM
LunchboxZT's Avatar
I thought there was only one? it's drilled into the test pipe.
Old Feb 9, 2007 | 11:33 AM
RTW DC2R's Avatar
chances are the O2 sensor is too close to the exit of the test pipe, causing the mixture at the sensor to get fresh air sucked into the test pipe because there is no cat back, and causing the CEL. this is why when I had to get tuned with no cat, I needed to relocate my O2 sensor bung much farther away from the end of the downpipe, it will throw off the readings. check the CEL just to be safe, its probably secondary O2.
Old Feb 9, 2007 | 11:35 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LunchboxZT &raquo;</TD></TR><TR><TD CLASS="quote">I thought there was only one? it's drilled into the test pipe.</TD></TR></TABLE>
No, there is a primary and secondary O2 sensor on all OBD2 cars. The secondary O2 sensor should be after the catalytic converter. Your car with throw a code without it.
LunchboxZT's Avatar
Default Re: (RTW DC2R)
Yeah I just checked it, 02 sensor is about 2.5 inches away from fresh air. I guess I'll find out when I throw the new catback on there and fire her up again.
Old Feb 9, 2007 | 11:36 AM
RTW DC2R's Avatar
It could just be the VTECH solenoid too. Let me know if you need one
Old Feb 9, 2007 | 11:50 AM
LunchboxZT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">It could just be the VTECH solenoid too</TD></TR></TABLE> lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">No, there is a primary and secondary O2 sensor on all OBD2 cars. The secondary O2 sensor should be after the catalytic converter. Your car with throw a code without it.</TD></TR></TABLE>
Ok now I'm confused. I don't remember EVER seeing an O2 sensor AFTER my test pipe / cat. Maybe I'm just smoking giant crack rocks? Here.. I went and took pictures.
So your telling me there should be another O2 sensor built into the catback exhaust?
PS. That is a DIY test pipe, and I'm not sure what header it is either, I think JDM ITR but I'm not positive, came with the car.
Modified by LunchboxZT at 1:16 PM 2/9/2007
Old Feb 9, 2007 | 11:55 AM
Mugen Mike's Avatar
Default Re: (LunchboxZT)
The secondary O2 sensor is on the exit end of the catalytic converter, there should be a bung for the primary O2 sensor just before the collector on the header.
Old Feb 9, 2007 | 11:58 AM
citrus3000psi's Avatar
There are 2 sensors...One before the cat convertor...One after....
The ecu does this magical thing called subtraction and subtracts 02 reading from the first from the second. If the difference isn't within a certain yield then the ecu thinks the cat is broken (or in your case not there).
But the car should be running in closed loop until it gets warmed up. So it shouldn't be reading 02 readings until its in open loop. Is your sensor physcally gone? or did it not throw the code until the car warmed up?
Old Feb 9, 2007 | 12:06 PM
LunchboxZT's Avatar
Default Re: (citrus3000psi)
Ok, I guess I am just smoking crack rocks, I climbed under there again and found the primary O2 sensor at the collector end of the header.
No, the CEL threw immediatly when I turned the car on. should I try to do the paperclip trick to see what CEL I'm getting? Or just wait until I have an exhaust?
Also, can anyone identify what header that is? I think it's a JDM ITR w/ 2.5 collector, not sure though.
Old Feb 9, 2007 | 12:12 PM
I would rather done the paper clip trick first before climbing under the car and have taken pictures.
Old Feb 9, 2007 | 12:22 PM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">I would rather done the paper clip trick first before climbing under the car and have taken pictures.</TD></TR></TABLE>
ditto
yes that looks like the JDM header.
Old Feb 9, 2007 | 12:29 PM
itr1244's Avatar
Old Feb 9, 2007 | 12:32 PM
walker111's Avatar
Check the cell, yes its a jdm 4-1 header
Old Feb 9, 2007 | 12:40 PM
tartje's Avatar
Default Re: (itr1244)
guys, i'm like 100% sure mine doesnt have two o2 sensors
Old Feb 9, 2007 | 12:44 PM
LunchboxZT's Avatar
Default Re: (tartje)
Okay.. so I did the paperclip trick..
Throwing the following codes
CEL: 22
ABS: 53
SRS: 11 - I have JDM non SRS wheel so this is to be expected.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-SpeedRacing &raquo;</TD></TR><TR><TD CLASS="quote">
CEL 22:
VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
* invalid code for non-VTEC engine
Anyone know what this is / how to fix heR?
RTW DC2R - will buying your Ported Vtec solinoid fix this problem? Haha...
Old Feb 9, 2007 | 12:46 PM
walker111's Avatar
22
94+ Integra VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
Old Feb 9, 2007 | 12:49 PM
Mugen Mike's Avatar
Default Re: (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">22
* invalid code for non-VTEC engine </TD></TR></TABLE>
Looks like it's time for one of Ryan's ported VTEC solenoids...
Old Feb 9, 2007 | 12:54 PM
LunchboxZT's Avatar
Default Re: (Mugen Mike)
Anyone know where the VTEC oil pressure switch is? how can I tell if it's damaged?
Also, anyone have a manual to see what ABS 53 is?
Old Feb 9, 2007 | 01:05 PM
walker111's Avatar
number 16
Search biotch
Old Feb 9, 2007 | 01:06 PM
walker111's Avatar
search again biznitch!!!
11 - wheel senor (open/short to body ground/short to power) FR
13 - wheel senor (open/short to body ground/short to power) FL
15 - wheel senor (open/short to body ground/short to power) RR
17 - wheel senor (open/short to body ground/short to power) RL
12 - wheel senor (electrical noise/intermittent interuption) FR
14 - wheel senor (electrical noise/intermittent interuption) FL
16 - wheel senor (electrical noise/intermittent interuption) RR
18 - wheel senor (electrical noise/intermittent interuption) RL
21 - pulser FR
22 - pulser FL
23 - pulser RR
24 - pulser RL
31 - solenoid (short to body ground/short to wire) FR-IN
32 - solenoid (short to body ground/short to wire) FR-OUT
33 - solenoid (short to body ground/short to wire) FL-IN
34 - solenoid (short to body ground/short to wire) FL-OUT
35 - solenoid (short to body ground/short to wire) RR-IN
36 - solenoid (short to body ground/short to wire) RR-OUT
37 - solenoid (short to body ground/short to wire) RL-IN
38 - solenoid (short to body ground/short to wire) RL-OUT
41 - wheel lock FR
42 - wheel lock FL
43 - wheel lock RR
44 - wheel lock RL
51 - motor lock
52 - motor stuck OFF
53 - motor stuck ON
54 - fail-safe relay
61 - ignition voltage
62 - ignition voltage
71 - different diameter tire
81 - central processing unti (CPU)
Old Feb 9, 2007 | 01:17 PM
LunchboxZT's Avatar
lol, thanks Walker111
