Torque Specs using ARP head studs??
Old Jun 2, 2002 | 11:08 PM
saso
Guest
Posts: n/a
Default Torque Specs using ARP head studs??
Stock B18c running about 10psi of boost and stock head gasket. What would you guys recommend to torque the head at using Arp head studs.
[Modified by saso, 8:12 AM 6/3/2002]
Old Jun 2, 2002 | 11:11 PM
Incognito's Avatar
Default Re: Torque Specs using ARP head studs?? (saso)
Friend of mine has a stock GSR motor, turbo, at 11psi. His ARP head studs were torqued at 69ft/lbs, stock head gasket.
Old Jun 3, 2002 | 01:31 AM
saso
Guest
Posts: n/a
Default Re: Torque Specs using ARP head studs?? (Incognito)
ttt
Old Jun 3, 2002 | 04:03 AM
sparkz's Avatar
arp reccomends 72ft/lbs using their supplied lube, 82 ft/b with 10-30 wt oil
Old Jun 3, 2002 | 04:57 AM
turbo Si's Avatar
Default Re: Torque Specs using ARP head studs?? (sparkz)
I remember ARP saying to torque them at 63ft lbs using there lube. Anyways it's all safe, as long as you don,t go below 63 I guess. Make sure you do a 2 or 3 step torque!
Old Jun 3, 2002 | 05:29 AM
X2BOARD's Avatar
Default Re: Torque Specs using ARP head studs?? (turbo Si)
Do you have the ARP moly lube ? It will make a difference. If you use the ARP moly lube, you will torque to lower specs. Otherwise you need to use a 30 weight oil and the higher specs....
b18C ARP head studs should be torqued in the following manner:
Torque all head studs in proper sequence in a 2 stage manner.
1st pass:
With ARP moly lube: 30 ft/lbs
or
With 30 weight oil: 40 ft/lbs
2nd pass:
With ARP moly lube: 65 ft/lbs
or
With 30 wieght oil: 80 ft/lbs
**Do not torque the b18c head studs tighter than 65 ft/lbs with ARP moly lube or 80 with 30w oil.
These figures are directly from ARP, triple check by myself and takes into account the aluminum head senario.
HTH
X2
[Modified by X2BOARD, 9:34 AM 6/3/2002]
Old Jun 3, 2002 | 07:52 AM
BoOsTeD_eK's Avatar
Default Re: Torque Specs using ARP head studs?? (X2BOARD)
That sounds about right...I took mine all the way to 78lbs.
Old Jun 3, 2002 | 02:57 PM
saso
Guest
Posts: n/a
ttt
allhonda
Mar 23, 2009 07:05 PM
gonmaro
Jan 29, 2009 12:05 PM
bodydropranger
Feb 3, 2003 03:10 PM
D16A6Turbo
Dec 2, 2002 11:24 AM
NorCalHB
Dec 1, 2002 10:37 PM
