how much torque on arp head studs
Old Nov 5, 2009 | 05:16 PM
Kr4nG's Avatar
Default how much torque on arp head studs
hey guys im about to install arp head studs on my rebuild and i was wondering what torque you guys are going with. the factory specs? or little more. also when in put the new studs on the block do i torque them in at 10 pounds? thanks
Old Nov 5, 2009 | 06:51 PM
jdm inc's Avatar
Default Re: how much torque on arp head studs
when u put the studs into the block your only suppose to hand tighten them. For when you torque the head down it should come with a torque sheet. I believe its 75-80 ft lbs i cant remember off the top of my head.
Old Nov 5, 2009 | 07:09 PM
cibao2ner's Avatar
7-3-1-5-9
8-4-2-6-10 use that sequence do 20lbs then 45lbs then 70lbs did this on lsvtec
never had a problem...when u tighten u go from inside out when u lossen do
from outside in..
Old Nov 5, 2009 | 10:35 PM
Scott_Tucker's Avatar
Go with what torque procedure ARP recommends with the lubricant that ARP recommends. The torque spec is fastener dependent, not make and model dependent.
Old Nov 6, 2009 | 02:48 AM
Kr4nG's Avatar
well i have the acura service manual. (huge book tells me how to do anything) anyway i was wondering if it was okay to tighten them with more torque then factory specs because of their strength. this arp paper says 80ft lbs of torque.
so lube them up with the grease they gave me and only hand tighten them in, put the gasket down, put the head on, put the washers in lubed up, then start tightening down from the acura manual. what else should i watch out for. thanks
slo_b18
Jan 30, 2008 08:47 AM
LudEcrous
May 4, 2004 01:47 PM
bodydropranger
Feb 3, 2003 03:10 PM
X2BOARD
May 17, 2002 10:51 AM
