ARP recommends to torque head studs to 60lbs (i think) but can...
you torque them down anymore w/ out any ill effects...if so what do LBS do you torque them down to...
Re: ARP recommends to torque head studs to 60lbs (i think) but can... (D16A6Turbo)
Depends on what lube you use on the threads. If you use ARP's antiseize, probably stock lbs are enough. Extra 5 lbs if lubed with oil. Probably could add a few lbs to both numbers without hurting anything.
Re: ARP recommends to torque head studs to 60lbs (gtcali)
funny mine said to torque them to 70 ft lbs with the arp moly lube and 85 with regular motoroil.
