d-series compression
Old 10-30-2009, 03:56 PM
  #26
schecter's Avatar
Default Re: d-series compression
well thanks, your input was very informative
Old 10-30-2009, 06:06 PM
  #27
jdmpoweredsol419's Avatar
Originally Posted by 93egSLEEPER
you are on the verge of having catistrophic failure or just having your motor die on you in the near future. it take a MINIMUM of 100 PSI to create combustion and burn fuel. below that you will develop a dead cylinder, have predetination and ruin pistons. being 7-14 points above that is not good.
Well, between being a cheapskate, and building a turbo motor (a mechanics state of mind..lol), my compression test results are 135,60,110,120. My car runs fine w/ 241,041 miles, original engine & trans. I've been driving now for probably two years w/ this compression. I burn about a qt of oil in 3500 miles, and I only get about 28mpg, but I can deal w/ that til March when I through my built Z6 in. My piston tops look fine, besides the carbon lol.
And when you do a compression test, you want the cylinder you are testing to have a full cycle. Intake, compression, power, and exhaust stroke. So you about 4 sec, or 4 cranks w/e suites you.
Old 10-30-2009, 06:44 PM
  #28
93egSLEEPER's Avatar
Originally Posted by schecter
non-vtec gives me delivery of power all throughout the rpm range with these motors i believe it to be more benificial to go non-vtec for boost.
WRONG, completely. the highes horsepower honda motor built all incorporate vtec. vtec is IMO the heart and soul of hondas makig power.
Old 10-30-2009, 08:43 PM
  #29
Autointeg's Avatar
healthy motor you have, did mines a couple days ago and im reading 180 1-3 and fourth 170 and my **** burns oil @ high rpms.. lol i need rings!! :D
Old 10-30-2009, 09:02 PM
  #30
Jimster480's Avatar
just because you burn oil at high RPM does not mean you need rings. Many honda's burn oil @ high RPM. My Vitara setup burns oil @ high RPM and my rings are fine.
Old 10-30-2009, 09:05 PM
  #31
Autointeg's Avatar
my **** smokes crazy and idles... its not actually high rpms, starts around 35
Old 10-30-2009, 09:07 PM
  #32
Jimster480's Avatar
burns at idle? Your compression is too high for that to happen lol. Maybe headgasket is leaking? and 3500 is pretty damn low for it to be burning oil. I remember my first Y8, that **** was TOTALLY WASTED. It didnt make power for ****, and yet it didnt burn oil (it just leaked it from the Rear Main Seal).
Old 10-30-2009, 10:51 PM
  #33
leroyb's Avatar
sounds about right got kinda the same number on my mini me (y7 to z6) at w.o.t
gsxr
02-04-2011 09:42 PM
guymosiris
03-31-2007 12:45 PM
Tad
06-27-2005 12:04 AM
delpoop!
10-27-2003 11:58 PM
Nameless RB26
04-10-2003 01:53 PM
Quick Reply: d-series compression
