how is a compression test done?
Old Oct 8, 2001 | 12:59 PM
gsxr's Avatar
Default how is a compression test done?
is this just a dealer thing?
thanks
Old Oct 8, 2001 | 01:02 PM
HX_Guy's Avatar
Default Re: how is a compression test done? (gsxr)
You get a compression gauge and unplug all the spart plugs. Screw in the compression gauge and turn the engine over about 5 times.
Old Oct 8, 2001 | 01:07 PM
mercury's Avatar
New User
c-speedracing.com, howto section
Old Oct 8, 2001 | 01:09 PM
mercury's Avatar
New User
Default Re: how is a compression test done? (HX_Guy)
That's the simple version, but that's also a real good way to blow out your ignition coil and ignitor...
Don't be stupid like me. Unplug that fuse!
Old Oct 8, 2001 | 01:48 PM
H23 Power's Avatar
http://www.c-speedracing.com/howto/c.../comptest.html
Old Oct 8, 2001 | 02:45 PM
Black SVT's Avatar
Default Re: how is a compression test done? (01GSR)
And remember consistancy is mostly what you are looking for.
Old Oct 8, 2001 | 07:17 PM
Chris's Avatar
Default Re: how is a compression test done? (mercury)
Please eloborate on that....
Old Oct 8, 2001 | 08:10 PM
mercury's Avatar
New User
Default Re: how is a compression test done? (Chris)
I just took out all the plugs and cranked over 5x for each cylinder. After I put everything back together, the car wouldn't start. No spark. When the coil charges up and has nowhere to discharge, you'll overheat the ignition coil and/or the ignition control module.
Old Oct 8, 2001 | 08:14 PM
Chris's Avatar
thanks! I think I might need one!
Old Oct 9, 2001 | 09:50 AM
'94gsR's Avatar
New User
i had no idea a compression test was that simple...thats childsplay...cool.
Old Oct 9, 2001 | 04:15 PM
rockwilda's Avatar
Default Re: how is a compression test done? ('94gsR)
what happens when compression is off? what does a mechanic do to fix it?
just wondering...i need a compression test
Old Sep 22, 2005 | 06:30 PM
SingeBgd's Avatar
Default Re: how is a compression test done? (rockwilda)
that all depends ur piston rings could be gone thats one of the things and i think thers 2 ither things, some1 fill me in on this...
Old Nov 25, 2005 | 12:52 PM
Nuno EuroVTi's Avatar
Default Re: how is a compression test done? (SingeBgd)
many things lead to a bad comp test:
examples:
-Bad valve ajdustment
-Funked valve seats
-Compression rings
-Bad Gasket
Old Dec 10, 2005 | 09:06 PM
torqueless's Avatar
Default Re: how is a compression test done? (Nuno EuroVTi)
is there like an injector fuse that you un-plug, so that you dont flood the motor?
Old Dec 10, 2005 | 09:11 PM
PrinceAli132's Avatar
Default Re: how is a compression test done? (torqueless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra Type R FAQ &raquo;</TD></TR><TR><TD CLASS="quote">Engine - Testing - Compression test
http://www.c-speedracing.com/h...t.php
Engine - Testing - Leak Down test
https://honda-tech.com/zerothread?id=438893
Ali
Old Dec 10, 2005 | 09:13 PM
juicy629's Avatar
Default Re: how is a compression test done? (PrinceAli132)
ya youll be pumping fuel into those explosion chambers.. also a compression test doesnt always tell you half the problems you could have.. a true test would be a leak down test.. if you have bad compression test youll know before you test..
Old Dec 10, 2005 | 11:56 PM
Sar Face's Avatar
Default Re: how is a compression test done? (juicy629)
unplug your injectors, and distrubator, then run the test. Your not gonna fu@k anything else up
Old Dec 11, 2005 | 07:15 AM
racekar711's Avatar
is a leak down test similar? use the leak down test device but do you have to rotate the crank for each cylinder to tdc? the c speed site doesnt say to do that but i remember hearing that from past threads but not sure if they know what they are talking about
Old Dec 11, 2005 | 07:35 AM
mmuller's Avatar
Mad Scientist
Default Re: (racekar711)
no you dont put anything at tdc; just unplug your dizzy, unplug your main relay(or disconnect injectors, fuel pump, etc.), hold the throttle open and crank 5-7 times.
Old Dec 11, 2005 | 04:08 PM
racekar711's Avatar
Default Re: (mmuller)
i was referring to leak down test sorry
Old Jan 13, 2006 | 08:29 AM
CRXstress's Avatar
thnks
Old May 17, 2006 | 03:31 PM
Nors's Avatar
Default Re: how is a compression test done? (Mrwool983455)
Should I be worried about disabling the ignition? Or will pulling the fuel injectior fuse suffice?
Old May 18, 2006 | 07:01 AM
Nors's Avatar
anyone???
Old May 18, 2006 | 07:40 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (Nors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nors &raquo;</TD></TR><TR><TD CLASS="quote">Should I be worried about disabling the ignition? Or will pulling the fuel injectior fuse suffice?</TD></TR></TABLE>
Yes pull the fuse, I think it is 15A or 14A, you are supposed to
Old May 18, 2006 | 07:58 AM
VHOA's Avatar
Default Re: (SlammedDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SingeBgd &raquo;</TD></TR><TR><TD CLASS="quote">that all depends ur piston rings could be gone thats one of the things and i think thers 2 ither things, some1 fill me in on this...</TD></TR></TABLE>
its good to see people are actually using the search feature
