Precision 67/65 vs Turbonetics-HPC 64/65 Dyno
Old 05-28-2011, 01:40 AM
.CUBISH.'s Avatar
Default Precision 67/65 vs Turbonetics-HPC 64/65 Dyno
I've used both of these turbos on a lot of high HP car but havent had a chance to do both of them back to back.. here is a car that i finished up tonight on relatively low boost..
setup:
84x89 lsvtec
9.5 to 1 compression je pistons
eagle rods
stock port b16 head
stock b16 cams
Victorx intake
open T4 topmount
precsion 750 intercooler
E85
S300
67/65 is journal bearing with a .68 back housing
64/65 is ball bearing with a .81 back housing
both are on 18 psi
Red line= Precision 67/65 journal bearing
Blue line= Turbonetics-HPC 64/65 Ball Bearing
Old 05-28-2011, 02:11 AM
SlowReaction's Avatar
Default Re: Precision 67/65 vs Turbonetics-HPC 64/65 Dyno
Should have used the .81 on both turbos. I believe they are interchangeable? I just picked up one for a customers car, good to see some number since I havent seen anyone else using these.
Old 05-28-2011, 02:14 AM
.CUBISH.'s Avatar
i did a back to back previously with the 67 with both rear housings...spool was even worse... no point comparing the 64 to that...
Old 05-28-2011, 02:16 AM
.CUBISH.'s Avatar
i did a stock bore/stroke b16 back in december with the 64/68. made 800hp on 36psi
Old 05-28-2011, 02:25 AM
Good to know. Thanks for the comparison. Might have to try one of these 6465 in my own car.
Old 05-28-2011, 06:36 AM
96 GSR-T's Avatar
Nice comparison, probably 100whp sitting on the table with a good cam swap, shame such a setup has the most horrible cam available in it.
Old 05-28-2011, 06:41 AM
HELLO,GOOD MORNIN'
ahobbs's Avatar
interesting, thanks for the comparison
Old 05-28-2011, 06:27 PM
Casey's Avatar
nice comparison. what would change at higher hp levels? is this the billet turbonetics? i was trying to find it on their website
Old 05-28-2011, 08:02 PM
.CUBISH.'s Avatar
yeah its the billet Turbonetics... hard to say on higher boost levels, but i have made 850hp on the 64 before so i dont see it falling off too much compared to the 67 on higher boost
Old 05-29-2011, 12:52 PM
DelSolMarine's Avatar
if the precision was a ball bearing turbo like the turbonetics one that would have made for more of a fair comparison as well... still interesting
Old 05-29-2011, 03:06 PM
.CUBISH.'s Avatar
a lot of things could have made it more fair... same housings..bb..etc.. but these are the turbos i had. point was to show that the billet 64 is a very capable turbo
ashtons300zx
01-18-2013 06:59 AM
MAperformance
09-12-2009 07:59 AM
nos51
06-30-2009 11:25 AM
yellowhonda88
12-04-2006 11:10 AM
-Trinitron-
09-11-2003 02:02 PM
Quick Reply: Precision 67/65 vs Turbonetics-HPC 64/65 Dyno
