Help with Profec B
Old 02-22-2003, 11:52 PM
B20-T's Avatar
Default Help with Profec B
How do i set this thing to boost at 8psi?and i need help on hooking it up..I am confuse where to hook up the (In)nipple from the Greddy motor to.the out i hook up to the wastegate.can someone help me thanks
Old 02-23-2003, 12:20 AM
MiraiZ's Avatar
Default Re: Help with Profec B (B20TURB0)
before a million people flame you for not doing a search, here's the post your are looking for:
https://honda-tech.com/zerothread?id=328052
Old 02-23-2003, 05:23 AM
niedejb's Avatar
Default Re: Help with Profec B (MiraiZ)
If your WG spring has a higher rating than 8psi you wont be able to.
Old 02-23-2003, 08:07 AM
B20-T's Avatar
Default Re: Help with Profec B (niedejb)
i have a .45 bar in there which is 6.53 lbs i think
Old 02-23-2003, 08:10 AM
niedejb's Avatar
Heres how I have mine hooked up and it works great. Others use connections that didnt work for me (like the Greddy instructions).
Compressor nipple to the in
The out on the Profec to the side of the Tial (top is left open to air)
Old 02-23-2003, 10:34 AM
New User
1fstevo's Avatar
Default Re: Help with Profec B (B20-T)
I have profec-B and HKS wastegate. Had this setup a while now and never had an problem. I have always set the boost at 12 psi max. Just recently I cranked up the boost to 18 pound and ran on the dyno, no problem. However, ever since I cranked it up, I have problem setting it back to 12 pound on the street. It just creepes all the way up to 18 pound when I bring the motor to 7000 rpm in third. Almost like the wastegate is trying to set the 12psi goal but got overtaken at high rpm. I set both **** back to zero and it still does it. I havn't had time to further diagnostic the problem but I really think it's either the wastegate or the profec unit.
Btw, I have full 3inch dp and 3in thermal exhaust, no cat. SFP manifold. ( it's not the exhaust unit since I can control it very well before. )
turbotime
09-10-2006 05:12 PM
adseguy
11-12-2005 09:26 AM
PA MATT
07-16-2005 08:10 AM
94lsboost
02-05-2005 07:54 AM
Dampach1
03-25-2004 05:53 PM
Quick Reply: Help with Profec B
