Help with Profec B
Old Feb 22, 2003 | 11:52 PM
B20-T's Avatar
Default Help with Profec B
How do i set this thing to boost at 8psi?and i need help on hooking it up..I am confuse where to hook up the (In)nipple from the Greddy motor to.the out i hook up to the wastegate.can someone help me thanks
Old Feb 23, 2003 | 12:20 AM
MiraiZ's Avatar
Default Re: Help with Profec B (B20TURB0)
before a million people flame you for not doing a search, here's the post your are looking for:
https://honda-tech.com/zerothread?id=328052
Old Feb 23, 2003 | 05:23 AM
niedejb's Avatar
Default Re: Help with Profec B (MiraiZ)
If your WG spring has a higher rating than 8psi you wont be able to.
Old Feb 23, 2003 | 08:07 AM
B20-T's Avatar
Default Re: Help with Profec B (niedejb)
i have a .45 bar in there which is 6.53 lbs i think
Old Feb 23, 2003 | 08:10 AM
niedejb's Avatar
Heres how I have mine hooked up and it works great. Others use connections that didnt work for me (like the Greddy instructions).
Compressor nipple to the in
The out on the Profec to the side of the Tial (top is left open to air)
Old Feb 23, 2003 | 10:34 AM
1fstevo's Avatar
New User
Default Re: Help with Profec B (B20-T)
I have profec-B and HKS wastegate. Had this setup a while now and never had an problem. I have always set the boost at 12 psi max. Just recently I cranked up the boost to 18 pound and ran on the dyno, no problem. However, ever since I cranked it up, I have problem setting it back to 12 pound on the street. It just creepes all the way up to 18 pound when I bring the motor to 7000 rpm in third. Almost like the wastegate is trying to set the 12psi goal but got overtaken at high rpm. I set both **** back to zero and it still does it. I havn't had time to further diagnostic the problem but I really think it's either the wastegate or the profec unit.
Btw, I have full 3inch dp and 3in thermal exhaust, no cat. SFP manifold. ( it's not the exhaust unit since I can control it very well before. )
turbotime
Sep 10, 2006 05:12 PM
adseguy
Nov 12, 2005 09:26 AM
PA MATT
Jul 16, 2005 08:10 AM
94lsboost
Feb 5, 2005 07:54 AM
Dampach1
Mar 25, 2004 05:53 PM
