New Welding Thread!
Old Jan 23, 2004 | 08:02 PM
  #876
tony1's Avatar
Default Re: (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Is there a minimum bend diameter when making a manifold? How tight can you go before flow is restricted?</TD></TR></TABLE>
Any bend is bad for air flow. The bigger the radius the better. All those tight 90 degree bends are not good...
Old Jan 23, 2004 | 08:09 PM
  #877
hulkhb's Avatar
Default Re: (tony1)
Think of it as a Garden hose.......it still flows the same if its in a straight line or weither its coiled up, only when the line becomes "kinked" does flow become slow.
Old Jan 23, 2004 | 08:33 PM
  #878
matt_sb2000's Avatar
Default Re: (hulkhb)
I just made this the other day.
And I made the manifold for the silver srt4. hehehe
Old Jan 23, 2004 | 09:13 PM
  #879
CaptainMorgan's Avatar
which is stronger and better to make a manifold with.
316- 8 gauge
321- 16 gauge
both are stainless steel.
Old Jan 24, 2004 | 09:48 AM
  #880
Default Re: (doubler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubler &raquo;</TD></TR><TR><TD CLASS="quote">which is stronger and better to make a manifold with.
316- 8 gauge
321- 16 gauge
8 gauge probably. It's thicker.
Old Jan 24, 2004 | 09:56 AM
  #881
Neukin's Avatar
Default Re: (matt_sb2000)
matt_sb2000
looks like a rotory... you guys got it easy, two runners
Old Jan 24, 2004 | 10:18 AM
  #882
Sonny's Avatar
316- 8 gauge
321- 16 gauge
The 8 gauge will be stronger (due to its thickness) and less expensive. 321 is the best stainless alloy in terms of heat tolerance, but it is very expensive. One of 316's most desirable characteristics is its resistance to salt-water corrosion. It is used a lot in boat applications.
Burns makes all of their high end stuff out of 321. 304 is a good choice between price and strength/corrosion resistance.
Sonny
Old Jan 24, 2004 | 11:52 AM
  #883
sporkcrx's Avatar
Very nice matt!!!
Old Jan 24, 2004 | 01:48 PM
  #884
Archidictus's Avatar
Unceasing Measure
Default Re: (toyosupr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyosupr &raquo;</TD></TR><TR><TD CLASS="quote">dont they all use pop cans lol id like to see some IC piping in a car all made of pop cans im sure someone will do it. other then the clamp smashin the can i think it would work. might even be able to get sponsored by Mountain Dew or something.</TD></TR></TABLE>
That would be wicked, but wouldn't the cans either explode under boost or collapse under vacuum because of the wall thickness? If not, I think that would be hardcore to the max .
Tell Tinker to do it. He's insane, he'll do anything.
Old Jan 24, 2004 | 02:47 PM
  #885
RenoRacing's Avatar
Default Re: (Archidictus)
Till you hit a speed bump and it moves a little and tears your coors light 12 pack in half. it'll definately be a challenge, cause in order to use the cans you have to first drink them all. so welding them one at a time that's about one beer a minute.
Cody's definately down though, just give it a week and he'll have it done. lol
Old Jan 25, 2004 | 12:33 AM
  #886
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Very nice matt!!! </TD></TR></TABLE>
Thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyosupr &raquo;</TD></TR><TR><TD CLASS="quote">matt_sb2000
looks like a rotory... you guys got it easy, two runners </TD></TR></TABLE>
2 &gt; 4 hehehe
Old Jan 25, 2004 | 07:47 AM
  #887
Neukin's Avatar
first one to do it, ill send ya $10 i just think it would look cool to see all these cans welded together as intercooler piping.
matt_sb2000
maybe you should do it that rotor engine is going to need a nice intercooler, from what iv heard.
Old Jan 25, 2004 | 10:32 PM
  #888
EFb18b's Avatar
no, but seriously, what thickness do you guys use?
Old Jan 26, 2004 | 05:21 AM
  #889
Tinker219's Avatar
Default Re: (RenoRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing &raquo;</TD></TR><TR><TD CLASS="quote">Till you hit a speed bump and it moves a little and tears your coors light 12 pack in half. it'll definately be a challenge, cause in order to use the cans you have to first drink them all. so welding them one at a time that's about one beer a minute.
Cody's definately down though, just give it a week and he'll have it done. lol</TD></TR></TABLE>
lol. First I want to make a mountain bike frame using pop cans as a downtube. Itd take more than a week, my del slo is taking up any extra free time that I may have(or collector cutting time).
I just use 1/8th inch thick IC end tanks. Fairly easy to work with, and you can cruise along because the amperage can be turned up w/out as much worry of burn-through.
Old Jan 26, 2004 | 09:47 AM
  #890
maybe you should do it that rotor engine is going to need a nice intercooler, from what iv heard.</TD></TR></TABLE>
haha No.
Old Jan 26, 2004 | 10:44 AM
  #891
EFb18b's Avatar
Default Re: (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">
I just use 1/8th inch thick IC end tanks. Fairly easy to work with, and you can cruise along because the amperage can be turned up w/out as much worry of burn-through.</TD></TR></TABLE>
Great thanks alot Cody
Old Jan 27, 2004 | 02:43 PM
  #892
legendboy's Avatar
Default Re: (Redlineracer)
Here are a couple pics of the welders and the plasma in my shop
here is the tig thats older than me
Old Jan 27, 2004 | 02:50 PM
  #893
hulkhb's Avatar
Default Re: (legendboy)
Damn those are old But if it isn't broke dont fix it.
Old Jan 28, 2004 | 10:20 AM
  #894
LSiTurbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulkhb &raquo;</TD></TR><TR><TD CLASS="quote">Damn those are old But if it isn't broke dont fix it. </TD></TR></TABLE>
Thats what i say, my miller syncro. 300 is a 1976!!!!!!!! she still welds as good as any.
OT: Im wondering if any of you guys know where i can get some 2" mandrel bent steel pipes. I know Jegs has them, but im also looking for a 45* bend aswell. i need them for an IC pipe setup in a Nissan.
45* 2" mild steel?? anybody?
Thanks,
-Brian W.
Old Jan 28, 2004 | 02:17 PM
  #895
EFb18b's Avatar
Default Re: (LSiTurbo)
this is one place you can get them at:
http://www.jcwhitney.com/webap...10101
Also, I believe that there is a place you can probably get them from in glen burnie off of 8th ave near Michael's
Old Jan 28, 2004 | 03:29 PM
  #896
LSiTurbo's Avatar
Also, I believe that there is a place you can probably get them from in glen burnie off of 8th ave near Michael's[/QUOTE]
Thanks!
You know the name? or an adress or a # to a place that might know the adress? Local would great.
-Brian
Old Jan 28, 2004 | 03:37 PM
  #897
EFb18b's Avatar
Its in my phonebook at home. When I get home I'll get it to you. I also believe there is a couple of steel suppliers in baltimore. I'll try to find them for you as well.
Old Jan 28, 2004 | 05:36 PM
  #898
EFb18b's Avatar
Brian,
Durrett-Shepard Steel Co Inc
410-633-6800
6800 E Baltimore St
Posner Industries
1-866-767-6377
810 Cromwell Dr
Glen Burnie
Let me know if they have anything. I found these two in the phonebook only a couple days ago and haven't really had a chance to call them up.
Old Jan 28, 2004 | 08:01 PM
  #899
legendboy's Avatar
some more crappy aluminum welding. i wish i had a newer tig with variable amperage foot control
Old Jan 28, 2004 | 08:03 PM
  #900
hulkhb's Avatar
they dont look too bad at all.
