Car won't go into Gear..need help ASAP!!!
The other day I'm coming back from dropping the wife off at the airport...(2 1/2hr drive one way) and everythings goin smooth but as soon as I'm on my way back and go to exit...I start to shift from fith th 4th and it won't go into any gear...not 3rd or 2nd...well I pul over and turn the car off...then procede to start the car up and put it in gear...again won't go so I try reverse and this bad grinding noise happens I take it outta reverse and then maigically went into all gears including reverse...what could be worn...
CLIFF NOTES...
Car didn't go into gear
Put into reverse bad grinding noise
Then went itno all gears includint reverse
Had full cluth the whole process by the way
CLIFF NOTES...
Time for a new clutch and possibly tranny.
When the clutch wears out, the splines on the pressure plate lose their action so to speak, not allowing the fork/throwout bearing to fully disengage the clutch from the flywheel, which would prevent you from going into gear.
As for your tranny, has it ever had any problems with grinds or popping out of gear before all of this?
Re: Car won't go into Gear..need help ASAP!!! (CHAMPwhteEK)
Never ever had any problems with it popping outta gear at all...what kinda clutch setup should I go with being that I'm running an all motor setup...B16 head GSR Block and Tranny...(built)..wondering if I should bother replacing the clutch or jus do what every1 says and jus save and upgrade to an LSD so I can get the most power out or jus do the clutch setup..all help appreciated thanks
Re: (Mista Bone)
hmmm.. i had the same problem myself.. couldnt get into gear. i was ready to buy a new clutch but then ive been told to check the clutch master cylinder and clutch slave first before spending $500+ on a new clutch. turned out that my clutch slave was leaking out and spent about $50 and bam, problem solved. bottom line is, check all the small things first, like leaks from the clutch master cylinder and clutch slave before spending $$$, wont hurt to check... GL!
Re: (jaydem7)
thanks for the help..hopefully its something small..if not finally gives me a reason too save up for LSD..hahaha
eg6madness
04-16-2008 07:02 PM
