At what PSI does the oil light turn on?
Old May 17, 2007 | 08:29 AM
HiProfile's Avatar
Default At what PSI does the oil light turn on?
I know it sounds like a dumb question, but its related to my gauges. I have a oil distribution block for my guage+turbo, and since I swapped the ports the two use, I'm getting 25-50% less oil pressure than before. At idle before adding the turbo kit, it was always >15psi on the gauge, now it drops to almost 5psi.
The problem with that is: I knew it was perfect pressure before adding the kit, but between adding it and changing spots, I really can't recall seeing where it was. I'm sure I saw good pressure at that point, but I just can't visually remember it. A engine builder I know said he's seen that a few times with oil dist. mani's, but I just want to be sure.
Old May 18, 2007 | 04:04 PM
HiProfile's Avatar
Default Re: At what PSI does the oil light turn on? (HiProfile)
Nobody knows what psi the stock pressure sender sends a signal?
Old May 18, 2007 | 06:04 PM
Bseriescoupe's Avatar
<4.xpsi as far as I remember.
Old May 23, 2007 | 09:29 AM
HiProfile's Avatar
Default Re: At what PSI does the oil light turn on? (Bseriescoupe)
Thanks
Old May 23, 2007 | 04:04 PM
Scott_Tucker's Avatar
why do you have the pressure gauge and the turbo on the same circuit? Since oil is being fed into the turbo there is going to be a pressure drop at the gauge.
sirtef9
Engine Machining & Assembly
Jun 8, 2017 04:56 PM
Stoney Lawson
Dec 19, 2016 04:11 PM
boostgegsr
Dec 6, 2011 07:01 AM
AJxr
Jun 17, 2007 05:55 PM
dAng! Kris
Jan 24, 2005 12:38 PM
