what kind of tranny for nitrous?
Old Jul 15, 2002 | 04:36 PM
whatVTEC's Avatar
Default what kind of tranny for nitrous?
what kind of tranny do u guys reccomend? i have a 94 LS in my 93 hatch and i'm planning on running direct port nitrous. should i stick with my LS or use GSR?
Old Jul 15, 2002 | 07:19 PM
Kataku2K3's Avatar
Default Re: what kind of tranny for nitrous? (whatVTEC)
Running the GSR tranny on your LS would give you slightly better gears then say a B16 tranny on a GSR. For nitrous that's what you want, just as in all motor make that motor wind up as fast as possible. Your gears will suck when cruzing on the freeway but it's all good right!!!!!!!!!!
Old Jul 15, 2002 | 09:13 PM
ocbeta's Avatar
Default Re: what kind of tranny for nitrous? (JDMspecEG6)
An aftermarket clutch, and a lightend flywheel would be good.
Get a chromoly, stay away from aluminum.
Old Jul 16, 2002 | 03:32 AM
Mista Bone's Avatar
D Tranny Guru
use the LS tranny with 20" tall slicks
use the GSR tranny with 22" tall slicks
Old Jul 16, 2002 | 06:55 PM
whatVTEC's Avatar
Default Re: what kind of tranny for nitrous? (Mista Bone)
well i already have 24.5x8x13 slicks and an ACT 4puck clutch but i'm just not sure what the best tranny would be. thanks for your help... keep posting
Old Jul 20, 2002 | 08:34 PM
Kataku2K3's Avatar
Have fun turning them.... My friend just raced his 97 GSR turbo coupe today on those slicks except they were by 9" instead of 8". He ran a 12.5@112 on 10.4psi. Those slicks are hella hard to burn out without boost. You might need ur n20 to do a burnout, hehe.... Latez
Old Jul 21, 2002 | 01:00 AM
Mista Bone's Avatar
D Tranny Guru
what burnout?????
yeah, it won't be easy.
Old Jun 16, 2003 | 01:31 PM
DOMKID's Avatar
sorry to bring this back from the dead. Can somebody recommend a tranny for my setup.
b18b, Skunk2 IM, I/H/E
I plan on spraying a 60 shot. Should i keep my LS tranny or go b16 tranny with ls 5th gear(for HW cruising)?
thanks for any advice.
Old Jun 16, 2003 | 01:57 PM
Kataku2K3's Avatar
Default Re: what kind of tranny for nitrous? (Dominican_Kid)
That's a hard one, nitrous likes to have easy power to the ground... Loading the motor with N20 just puts extra stress on the rings, etc... This is why you use short gears and/or a higher FD... As your motor is still nonVTEC this is a hard call... If you still have your stock rev limit then your gears are going to go by really fast, perhaps too fast for nitrous... I think personally here I would stick with the LS tranny as it is meant for the motor... If you are planning on building this motor later on down the road with say a VTEC head, then I would just go with the B16 tranny now... The Y80/S80 GSR would be my choice for nitrous... It's gearing is pretty much inbetween B16 and B18A/B... Good Luck!!!
Old Jun 16, 2003 | 03:48 PM
DOMKID's Avatar
Default Re: what kind of tranny for nitrous? (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">That's a hard one, nitrous likes to have easy power to the ground... Loading the motor with N20 just puts extra stress on the rings, etc... This is why you use short gears and/or a higher FD... As your motor is still nonVTEC this is a hard call... If you still have your stock rev limit then your gears are going to go by really fast, perhaps too fast for nitrous... I think personally here I would stick with the LS tranny as it is meant for the motor... If you are planning on building this motor later on down the road with say a VTEC head, then I would just go with the B16 tranny now... The Y80/S80 GSR would be my choice for nitrous... It's gearing is pretty much inbetween B16 and B18A/B... Good Luck!!!</TD></TR></TABLE>
cool. thanks for the advice.
Lmgrcivic
Jul 24, 2006 06:37 AM
Endoe
Nov 24, 2004 01:04 PM
EFb18b
Sep 30, 2003 07:31 PM
whatVTEC
May 20, 2003 04:48 PM
turbospool
Apr 12, 2003 09:55 PM
