car won't start! problems for thief-recovered ITR
okay so my friend decided to rebuild himself an ITR ...bought a 2000 ITR shell (completely stripped down to the bones) and build it from there...now here the problems
car won't start!!
no check engine light
has fuel in the injectors/fuel rail
distributor is fine
car does crank
99 engine wiring harness (checked the wires all same as 00-01)
therefore, no power going to the injectors
would this have anything to do with the immobilizer?
he bought a complete set of immobilizer/keys/ignition switch from the dealer (which is the original one for the car)
but the ECU is not the same one (bought it off a H-T member)
any help would be great...hate to see a nice itr sitting in the garage and not able to drive it...!!!!
if need anymore details/specs let me know
oh yeah if i help him fix it i get to drive it too
car won't start!!
distributor is fine
car does crank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">what year is the ECU? does the CEL go off after 2 seconds of the key being on the ON position?</TD></TR></TABLE>
the ECU is 00 or 01 i forgot which (im sure either one will work)
and yes the check engine light (CEL) goes off after 2 second
You need the Keys/Imoblizer,and ecu the are a matched set Acura does however have a specal code to disarm the imobilizer...
I remember reading an article in SCC mag in the past about the security measures on the newer (2000+)cars. If I remember correctly, when doing swaps, the ECU and the key/immobilizer have to match -
I believe you have to go to a dealer, show them the reciept of the legal purchase of the engine, and they'll make sure the immobilizer/ECU will agree with each other - (don't know if they make new keys ???)
That article in Sport Compact Car was for a newer CTR I believe -
Good Luck -
Tom
Good Luck -
Tom
i called the dealer again and they said that the whole car would have to be brought in so they can reprogram the immobilizer/key/ignition switch to work with the ecu...for 86 dollars..but the car is about 60 miles from the dealer!!!
anyone else has a better solution or an easier way?
no the dealer wont reprogrammer it if we just bring in the immobilizer and ecu....
theres someon here on this board that posted a while back that they could disable the immobilizer in the ecu so u wouldnt have that problem. im not sure who it was though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy »</TD></TR><TR><TD CLASS="quote">theres someon here on this board that posted a while back that they could disable the immobilizer in the ecu so u wouldnt have that problem. im not sure who it was though</TD></TR></TABLE>
yes i read about that but i also read somewhere that its a pain in the *** to start the car w/out the immobilizer ..you got to key on key off etc...of course its cheaper but my friend wants it to be exactly like "stock"...he spent way less than how much a typical 00 itr would cost anyways
katman can disable an immobilizer, but it will always throw a CEL every time the car is started with code "internal circuit failure" because the ECU knows the immob has been disabled. just tell your friend to get an obd2-->obd1 conversion harness, and a chipped P28 ECU and he'll be good to go. otherwise the dealer is your only option.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC »</TD></TR><TR><TD CLASS="quote">katman can disable an immobilizer, but it will always throw a CEL every time the car is started with code "internal circuit failure" because the ECU knows the immob has been disabled. just tell your friend to get an obd2-->obd1 conversion harness, and a chipped P28 ECU and he'll be good to go. otherwise the dealer is your only option.</TD></TR></TABLE>
yeah i read about katman here and on jdmhondaparts.com
my friend is thinking about getting rid of the immobilizer...cheaper i guess
thanks for all the help!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ion_four »</TD></TR><TR><TD CLASS="quote">why don't you just disable it long enough to get it to the dealer, then re-enable it and have them fix it?</TD></TR></TABLE>
once you immobilize an ecu thats it. no more fixing it. you have to buy a new one if you want the immobilizer again.
and as for converting to OBDI i would suggest against this. it will make the car emissions illegal and will never pass.
just suck it up and get it to the dealership some how.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLOW4drINTEG »</TD></TR><TR><TD CLASS="quote">
It's not so much they wont do it, they can't do it without the car. They have to plug their scantool into the DLC.
</TD></TR></TABLE>It's not so much they wont do it, they can't do it without the car. They have to plug their scantool into the DLC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
It's not so much they wont do it, they can't do it without the car. They have to plug their scantool into the DLC.</TD></TR></TABLE>
yeah thats what they told us...i guess we going to bring the car to the riverside dealer...since the car is around there
Whynam
Jun 11, 2007 12:13 AM
