2 Simple questions for you Engine Buffs!!
Old Jan 7, 2003 | 03:27 PM
2muchPSI's Avatar
Default 2 Simple questions for you Engine Buffs!!
Hey guys, I have two things to ask of you. First, what is the torque specs on the cam gear bolts for a b17 engine. My manual said 27 ft/lbs, but that seemed a little light. Also, when replacing a timing tensioner, what do u guys look for to line it up. Do you replace the belt and use the tensioner to get it relatively tight? And what do I torque the bolt to on the timing tensioner. IF anyone out there can help me it would be greatly appreciated. Once again this is a B17 Engine out of a 92 GSR. Thanks
Old Jan 7, 2003 | 03:43 PM
baonest1's Avatar
Default Re: 2 Simple questions for you Engine Buffs!! (92tealvx)
yup.. 27ft/lb is right for the cam gear bolt.. and 40 fl/lb for the tensioner bolt. i just did that last night. its in the helms.
peace
Old Jan 7, 2003 | 03:44 PM
Kataku2K3's Avatar
Really people say that the specs are different from the year change... ie the 1st Gen B16A to todays 99-2000 Si but I don't really go by it.. We've had this debate about the cam caps and rail bolts.... Anyways I torque DOHC VTEC motors cam gears to 37ft/lbs and nonVTEC (B18A/B B20B/Z) to 27ft/lbs.. That's the correct spec for all the newer motors and you'll be fine with that.. Peace
EDIT: Damn Baonest you got that up fast, well you can go by that spec if you want but i still do 37... 40 is correct for the tensioner.... I guess that's never changed over time...
[Modified by Kataku2K3, 4:46 PM 1/7/2003]
Old Jan 7, 2003 | 05:29 PM
baonest1's Avatar
Default Re: 2 Simple questions for you Engine Buffs!! (Kataku2K3)
hmm interesting.. in my helms book for 1998 acura. it says 27 for the cam gear bolt. ima double check it. might even go up to 30-31.
thanx
Old Jan 7, 2003 | 07:11 PM
Kataku2K3's Avatar
Default Re: 2 Simple questions for you Engine Buffs!! (baonest)
Are you sure that you aren't looking at specs for a B18A/B?? hehe I know for a fact that those are 27ft/lbs, and i'm positive that the newer DOHC VTEC motors are 37ft/lbs..... Lemme know what your book says ... Latez
Old Jan 7, 2003 | 09:29 PM
baonest1's Avatar
bahhhh humbugg... ur right. i just checked it out.. it says 41ft/lb. geez, good think i found this thread. thanx for the heads up man
peace
Old Jan 7, 2003 | 10:08 PM
The Mole's Avatar
i got here too late, but you are correct, 41ft lbs is what it says in my helms GS-R manual.
chris
USDM EG
Feb 28, 2006 12:20 PM
Tim2179
Aug 28, 2005 06:02 PM
W.O.P.
Mar 17, 2004 10:39 PM
2muchPSI
Mar 18, 2003 06:46 PM
Nate B
Oct 18, 2002 01:36 PM
