vtec problem
i just did an obd2 gsr swap into my ek and it was running just fine for around 4 days. then when i started to hit vtec the whole car would jiggle back and forth and the speedo and tach would just go crazy. i'm not sure what could be causing it. i've already replaced the distributer and that doesnt seem to be the problem. i'm running an obd2 gsr ecu and i'm throwing the secondary o2 sensor, fuel pressure, ,and crank position sensor. plz help! thanks
oil level is full and the same codes are showing up. i'm wondering if this is a fuel problem. because vtec still engages but it just pukes out but keeps going. its happeing in the lower rpm's also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm123 »</TD></TR><TR><TD CLASS="quote">oil level is full and the same codes are showing up. i'm wondering if this is a fuel problem. because vtec still engages but it just pukes out but keeps going. its happeing in the lower rpm's also. </TD></TR></TABLE>
put a fuel gauge on there to see the fuel pressure
u may have a bad pump
