vtec problem
Old Sep 5, 2005 | 08:09 PM
jdm123's Avatar
Default vtec problem
i just did an obd2 gsr swap into my ek and it was running just fine for around 4 days. then when i started to hit vtec the whole car would jiggle back and forth and the speedo and tach would just go crazy. i'm not sure what could be causing it. i've already replaced the distributer and that doesnt seem to be the problem. i'm running an obd2 gsr ecu and i'm throwing the secondary o2 sensor, fuel pressure, ,and crank position sensor. plz help! thanks
Old Sep 5, 2005 | 09:06 PM
jdm123's Avatar
Default Re: vtec problem (jdm123)
bump! plz help me!
Old Sep 5, 2005 | 10:54 PM
rev-speed's Avatar
make sure oil level is full
then erase the codes and drive it to see what comes back and go from there
Old Sep 6, 2005 | 02:09 PM
jdm123's Avatar
Default Re: (rev-speed)
oil level is full and the same codes are showing up. i'm wondering if this is a fuel problem. because vtec still engages but it just pukes out but keeps going. its happeing in the lower rpm's also.
Old Sep 6, 2005 | 03:59 PM
licknilley's Avatar
the correct ckp sensor reading is needed for vtec. check all the wires on and neer the ckp sensor
(bottom of lower timing cover)
Old Sep 6, 2005 | 08:27 PM
rev-speed's Avatar
Default Re: (jdm123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm123 &raquo;</TD></TR><TR><TD CLASS="quote">oil level is full and the same codes are showing up. i'm wondering if this is a fuel problem. because vtec still engages but it just pukes out but keeps going. its happeing in the lower rpm's also. </TD></TR></TABLE>
put a fuel gauge on there to see the fuel pressure
u may have a bad pump
b17itr
Aug 3, 2009 05:58 PM
integraluva04
Jun 29, 2008 10:27 AM
91EF_Si
Feb 23, 2008 07:53 AM
jdm123
Sep 7, 2005 02:27 PM
89sir-9
Jun 18, 2002 11:02 AM
