vtec problem
Old Aug 3, 2009 | 05:52 PM
b17itr's Avatar
Default vtec problem
just finish installing h22 swap in my 96 accord- my problem is if vtec pressure sensor is hooked on- it bogs down and dies. it will not start until you disconnect vtec pressure sensor-i installed new sensor but still happens- no codes when car dies and vtec pressure sensor code if disconnected- any ideas- is my ecu the problem- got ground and voltage at the pin, thanks peeps
Old Aug 3, 2009 | 05:58 PM
nus_dogg's Avatar
Default Re: vtec problem
Are you sure you got the right connector hooked up? or there might be a short somewhere.
TristanW10
Mar 15, 2010 03:33 PM
vtecRDS
13
Jun 6, 2005 01:53 PM
98jdmdc2
Jun 1, 2004 07:00 PM
89sir-9
Jun 18, 2002 11:02 AM
