vtec not engaging correctly
Old Jul 22, 2013 | 09:41 AM
  #26
raverx3m's Avatar
Default Re: vtec not engaging correctly
well does it cut out at the exact spot where vtec engages or not?
move vtec up and see where it cuts out
Old Jul 28, 2013 | 05:21 PM
  #27
90ED6LSV's Avatar
Well i still haven't had a chance to put in that wideband, it's still in my brothers turbo 350z from tuning a basemap for it.
But i tried loading a stock tune and swapped to stock injector and it still does the same exact thing. It does it just revving the engine, partial throttle, full throttle, everything. I know it is something mechanical so any other input would be appreciated. I think the only test i haven't done yet is putting a mechanical oil pressure gauge on the front port by the vtec solenoid and checking for 60psi there.
Old Jul 28, 2013 | 05:23 PM
  #28
90ED6LSV's Avatar
Yes, whether i set vyec at 4500, 5000, 5500 it does the same thing. I might try to find a vtec dizzy, I'm using my non vtec dizzy with a leg cut off, ghetto old school way of doing it but i know that still works that way..
Old Jul 28, 2013 | 06:54 PM
  #29
slowDB7's Avatar
Old Jul 30, 2013 | 06:09 PM
  #30
90ED6LSV's Avatar
Originally Posted by slowDB7
Does that mean you hold an answer? If not then kindly refrain from posting.
Would having no o2 sensor cause this? My buddy was actually having a similar problem, we thought it was because sometime wired in vtec wrong but he put in a rear 02 sensor he was missing and now his vtec works fine. I have mine disabled but it has nothing plugged in, it probably won't help but it's worth a try.
rwlsvtec_03
Aug 8, 2011 08:24 AM
yeungkaho
Mar 21, 2007 04:59 PM
kasted1
Aug 20, 2002 09:16 AM
b20b
Feb 22, 2002 03:42 AM
zdr262
Oct 23, 2001 09:29 PM
