vtec no working !!!!
Old Oct 27, 2009 | 07:26 AM
vtieg6's Avatar
Default vtec no working !!!!
can someone help me!
why my vtec no working and i have check all my wiring, sensor and switch all working fine...
i have change ecu too (P30)
Old Oct 27, 2009 | 02:06 PM
civicjunkie17's Avatar
Default Re: vtec no working !!!!
how do you know its not working? you know vtec isnt really that big of a difference right? its not like as soon as you enter vtec you gain like 500 horsepower..
Old Oct 28, 2009 | 05:42 AM
vtieg6's Avatar
cause i try on my own and friend vehicle, while i accelerate to 3500 rpm i have 12 volt reading at multimeter for my friend vehicle and my reading only 2 volt plus. both same vehicle.
and the power of both car are totally difference
Old Oct 28, 2009 | 07:34 AM
mouab18c1's Avatar
try cleaning the screen on the vtec solenoid and check your wiring again
Old Oct 29, 2009 | 05:20 AM
vtieg6's Avatar
i clean vtec solenoid before.. ever swap vtec solenoid with my friend and working fine on his car. BTW wat wire should i check again
Old Oct 29, 2009 | 07:43 AM
vtieg6's Avatar
is there anything do with CEL no.20 (ELD) causing vtec no working??
Old Oct 30, 2009 | 04:50 AM
vtieg6's Avatar
help help
Old Oct 30, 2009 | 07:17 AM
mouab18c1's Avatar
check your ground wires....with code 20 it seems your having some electrical issue
Old Oct 30, 2009 | 10:18 AM
vtieg6's Avatar
i add 3 more ground to my car ready.. by the way my car don't have ELD but ecu have, do is affect??
Old Oct 30, 2009 | 08:28 PM
mouab18c1's Avatar
switch ecu and see what happens...and btw what motor and car is this?
Old Oct 31, 2009 | 06:11 AM
vtieg6's Avatar
wat ECU should i try and i drive eg6 engine B16a
Old Oct 31, 2009 | 06:17 AM
mouab18c1's Avatar
try a stock b16 ecu. or even an ITR...best way to go if you have it is a chipped p28 and find which basemap runs better on your car by testing them out. sometimes swapped motors with stock ecus run funny even though its the ecu for it. chipped ecu is the way to go.
Old Oct 31, 2009 | 06:48 AM
vtieg6's Avatar
got anything to do with ELD. CEL 20
Old Nov 1, 2009 | 07:59 AM
vtieg6's Avatar
bump
Old Nov 1, 2009 | 08:09 AM
mouab18c1's Avatar
your car might not have it but the ecu might, so its looking for it and of course the CEL will come on if the ecu cant find it
Old Nov 2, 2009 | 03:19 AM
vtieg6's Avatar
so now wat should i do, buy the ELD system to fix it or find a ECU without ELD and suitable for DOHC vtec engin??
pls help
thks bro
Old Nov 2, 2009 | 06:54 AM
mouab18c1's Avatar
try a chipped ecu with a basemap for your motor.
Old Nov 3, 2009 | 06:34 AM
vtieg6's Avatar
wat chip should i use??
Old Nov 3, 2009 | 06:37 AM
mouab18c1's Avatar
what do you mean what chip? you mean which basemap should you run?
Old Nov 6, 2009 | 05:11 AM
vtieg6's Avatar
yes wat basemap i should use??
Old Nov 6, 2009 | 06:47 AM
mouab18c1's Avatar
well i would say try a stock b16 map first. then if it's still the same try an ITR basemap
Old Nov 7, 2009 | 08:16 PM
vtieg6's Avatar
thk bro
i go try out hope it well work
Kova23
Engine Management and Tuning
Oct 15, 2012 11:25 AM
swizz977
10
May 25, 2011 08:15 PM
nitrousfedef9
11
Oct 5, 2005 09:13 AM
tuckin15s_8315
Sep 28, 2005 09:35 PM
swappedcivic
Dec 14, 2004 08:30 AM
