VALVE SEALS OR TURBO SEAL?? HELP
Old Dec 11, 2006 | 07:40 AM
SIXTY-1HATCH's Avatar
Default VALVE SEALS OR TURBO SEAL?? HELP
Alright fully built b18c1 piston rod setup with fully built head, valves springs retainers, all fresh from the maching shop.
valve seals were replaced along with valve job
since the day i fired the motor it has been smoking blue at odd times, mainly on decel and transitioning into boost.
The car doesn't smoke that bad on start up you can hardly tell the difference from smoke and steam on start up, but the second you give it gas right after that youll see smoke.
Compression came back 180 across the board and leakdown was 10% across the board motor seems to be in excellent health
with that said i have narrowed it down to oil rings, turbo, or valve seals the motor has bout 475 miles on it IT IS TUNED 100% since day one
i checked the other night after a cruise any i am consuming a large amount of oil like a full quart if i go boostin all night, can a turbo or valve seals use the much oil???i also have a catch can setup, but i definately do not have a quart in my catch can maybe a 1/4 of a quart and it hasn't taken any more
help diagnos me
Old Dec 11, 2006 | 11:10 AM
jays93eg6's Avatar
Default Re: VALVE SEALS OR TURBO SEAL?? HELP (SIXTY-1HATCH)
I suggest you remove your charge pipe and take a flashlight and check the turbo. If its using a quart of oil you should be able to tell. If its the valve seals they normally dont consume that much oil, but maybe that could also be it. You seem to be on the right track, but if the turbo is fairly new I would check into the valve seals. If the valve seals are damaged they will not seal the valve shut and oil spills into the combustion chamber and if you are driving the car hard then yes I could very well see a quart gone in a night. Hope this helps you kinda find your way.
Old Dec 11, 2006 | 11:30 AM
Default Re: VALVE SEALS OR TURBO SEAL?? HELP (jays93eg6)
yea thanks man i have check all piping for oil haven't really inspected the "internals" of the turbo but i will be tonight since im pulling it off and sending out to be inspected by garrett, the turbo wasn't new i bought it off a integra that made 500 hp so i know it's had ALOT of boost through it so im hoping thats all it is, but well see
thanx for the response
bigempty12
Mar 11, 2008 07:01 AM
EK FLY
Jul 1, 2007 02:52 PM
blackeg
May 1, 2007 01:59 AM
SIXTY-1HATCH
Dec 13, 2006 04:41 AM
xcellorator
Jun 8, 2006 02:41 PM
