smoke while decelerating?
Old Jun 4, 2006 | 02:48 PM
xcellorator's Avatar
Default smoke while decelerating?
i just finished my turbo install and i get some blue smoke when im decelerating. someone said it might be the valve seals, but could it be anything else? it never smoked before the turbo install.
Old Jun 4, 2006 | 04:54 PM
tonydatyga's Avatar
Default Re: smoke while decelerating? (xcellorator)
usually oil burning under decel and after sitting overnight means valve stem seals. See if you get any oil burning when you start the car up in the morning
Old Jun 4, 2006 | 07:18 PM
wade's Avatar
Default Re: smoke while decelerating? (tonydatyga)
usually valve seals are the culprit
Old Jun 4, 2006 | 07:45 PM
Got_soy's Avatar
i thought that when you got smoke durring decel was because of rings?
Old Jun 6, 2006 | 04:06 PM
Default Re: smoke while decelerating? (Got_soy)
no smoke when i start it up. its 100% only when the car is warmed up. how could i see if its the valve seals or rings? leakdown test? compression is 170-180 across. if i take it outta gear and slow down theres no smoke only when i leave it in gear and slow down.
Old Jun 6, 2006 | 04:09 PM
the intercooler piping is apart right now and its still smoking the same, no boost at all.
Old Jun 6, 2006 | 04:27 PM
turbotime's Avatar
i vote for valve seals, do a leakdown and see what you get
Old Jun 6, 2006 | 07:59 PM
tonydatyga's Avatar
doesn't seem like leadown would show you what the stem seals are doing if the valves are closed and sealing properly.
Old Jun 7, 2006 | 11:59 AM
wouldnt my compression be lower with bad valve seals? i gotta find a leakdown tester, how much does a mechanic charge anyway?
Old Jun 7, 2006 | 12:14 PM
Tchleung's Avatar
Well D/C IC pipes won't do anything. D/C the turbo. Maybe it's just the turbo
Old Jun 7, 2006 | 02:52 PM
b18ccivics's Avatar
Default Re: (Tchleung)
it is your drain line make sure it is big enough and straight as possible and doesnt go up hill. make sure you dont have too much oil and if all of that checks ok then it is your turbo seals. you decelerate then oil goes to the front of the pan therefore your drain doesnt drain as good.
Old Jun 8, 2006 | 02:41 PM
i thikn i will take the turbo off this weekend and see if it still smokes.
hondamatt89
Mar 17, 2015 11:19 AM
oranginal
Jul 3, 2009 11:37 AM
M@
Aug 23, 2005 09:24 AM
b16ahybrid
May 5, 2003 09:25 PM
