Valve clearence adjustment
Old Aug 11, 2003 | 06:44 PM
ChasRX's Avatar
Default Valve clearence adjustment
just had the complete b16a + loom from a EK transplanted in my 89CRX.My question might sound a bit stupid bcoz i haven pop the head cover to check inside.
My question is do i need to check valve lash on b16a head?...in case i pop a type r cam in it?...izzit runnin hydro valve lash adjustment or shims?
Thanks for the reply.
Charles
Old Aug 12, 2003 | 12:53 AM
.xcalibur.'s Avatar
Default Re: Valve clearence adjustment (ChasRX)
You will definitely need to do a valve adjustment when installing any kind of cams
Old Aug 12, 2003 | 12:26 PM
mike1114's Avatar
Default Re: Valve clearence adjustment (.xcalibur.)
I would check valve clearance as well as many other things if you just got a used motor. Timing belt, water pump, head gasket just to name a few others....
dem0nk1d
Apr 15, 2011 08:35 AM
maxogsr
Mar 20, 2010 04:17 PM
superfast666
Mar 26, 2008 12:11 PM
kornerk12
Aug 10, 2007 04:45 PM
6ghatch
Jan 22, 2002 06:29 AM
