more agressive cams & valve adjustments.
Old Aug 12, 2003 | 06:59 AM
genetsang's Avatar
Default more agressive cams & valve adjustments.
i searched but to no prevail... when using more aggressive cams in a b18c, will i be using stock specs or will there be a different set of specs that i should look into?
Old Aug 12, 2003 | 08:19 AM
genetsang's Avatar
Default Re: more agressive cams & valve adjustments. (genetsang)
Old Aug 12, 2003 | 09:14 AM
91integraLSVTEC's Avatar
your cams come with a spec sheet that tells you the valve lash..
Old Aug 12, 2003 | 09:39 AM
genetsang's Avatar
Default Re: more agressive cams & valve adjustments. (91integraLSVTEC)
well. thats if i bought then new... but i got them used so it doesnt come with the specs.. so basically if i get the cams new, it would with the specs with the valve adjustments specs?
Old Aug 12, 2003 | 10:29 AM
NonovUrbizniz's Avatar
Loved
contact the company who produces them they will provide the proper specs.
Old Aug 12, 2003 | 12:34 PM
genetsang's Avatar
Default Re: more agressive cams & valve adjustments. (NonovUrbizniz)
thanks.
jdmcivic2fast
Feb 4, 2012 08:38 PM
HYPROPULSION_R
Aug 5, 2007 07:52 PM
Daily Interlude
Mar 28, 2005 06:39 AM
infinkc
Feb 9, 2002 05:27 AM
Toda Party
Jan 8, 2002 11:25 PM
