valve seals and valve guides
Old Mar 24, 2008 | 09:19 PM
superfast666's Avatar
Default valve seals and valve guides
is there any way to check if the valve seals and valve guides leak with the head removed
Old Mar 25, 2008 | 08:50 AM
EnjoyTheRideDC2's Avatar
Default Re: valve seals and valve guides (superfast666)
If you already have the head removed, forget about checking the valve seals. You should change them out at that point. Its not very expensive for the set of 16 seals and it wouldn't make sense not to change them since you've got half the head already disassembled once you pulled it out.
To check valve guide wear, use a gauge set made for valve guides for the most accuracy. Some people slip a valve into the stem and wobble it around checking for looseness. If you can wobble the valve stem around while in the guide, and the valve is perfectly good and straight, chances are your guide is worn.
Old Mar 25, 2008 | 11:47 AM
Default Re: valve seals and valve guides (EnjoyTheRideDC2)
any one else
Old Mar 25, 2008 | 06:52 PM
blkb18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">If you already have the head removed, forget about checking the valve seals. You should change them out at that point. Its not very expensive for the set of 16 seals and it wouldn't make sense not to change them since you've got half the head already disassembled once you pulled it out.
To check valve guide wear, use a gauge set made for valve guides for the most accuracy. Some people slip a valve into the stem and wobble it around checking for looseness. If you can wobble the valve stem around while in the guide, and the valve is perfectly good and straight, chances are your guide is worn.</TD></TR></TABLE>What he said. Your going to replace the seals no matter what. The guides can easily be checked with the wobble method.
Old Mar 25, 2008 | 10:41 PM
Default Re: valve seals and valve guides (blkb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">What he said. Your going to replace the seals no matter what. The guides can easily be checked with the wobble method. </TD></TR></TABLE>
Exactly....You cant check the guides without first removing the seals. And valve seals ARE NOT reuseable.
Old Mar 25, 2008 | 11:24 PM
egb18c5's Avatar
Exactly....You cant check the guides without first removing the seals. And valve seals ARE NOT reuseable. </TD></TR></TABLE>
especially when u dont have the proper tool to remove them
Old Mar 26, 2008 | 12:11 PM
Default Re: valve seals and valve guides (egb18c5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb18c5 &raquo;</TD></TR><TR><TD CLASS="quote">
especially when u dont have the proper tool to remove them </TD></TR></TABLE>
hehe, I know what you mean. But even with the proper tool, they still should not be removed and replaced. Valve Seals are like condoms, you dont reuse them.
maxogsr
Mar 20, 2010 04:17 PM
superfast666
Mar 25, 2008 11:57 AM
vinuneuro
Apr 24, 2007 06:05 AM
cdizzle
Feb 16, 2006 12:33 PM
BigC-ivic
Oct 22, 2004 02:46 PM
