Valve adjustment? B16a
Old Jan 21, 2002 | 06:36 AM
6ghatch's Avatar
Default Valve adjustment? B16a
If you put in new cams, gears, valve springs, and retainers, will this affect the need for valve adjustments and will the factory specs still be maintained?
Old Jan 21, 2002 | 12:51 PM
B19CivicHB's Avatar
Default Re: Valve adjustment? B16a (6ghatch)
always re-adjust yer valve clearances if you mess with the valvetrain at all
Old Jan 21, 2002 | 02:38 PM
3rdGteg's Avatar
Default Re: Valve adjustment? B16a (B18CivicHB)
Depending on which type of cams you're using, your valve lash specs may vary.
Old Jan 21, 2002 | 04:20 PM
coquinn's Avatar
Always readjusted your valves to the specifications recommended by the camshaft manufacturer.
Old Jan 21, 2002 | 08:30 PM
BTR ALL MOTOR's Avatar
yes, re-adjust the valves....it only takes about 15 minutes.....i had mine adjusted the other day....always make sure the valve clearances are good....
Old Jan 22, 2002 | 06:29 AM
Spade's Avatar
Default Re: Valve adjustment? B16a (BTR ALL MOTOR)
And don't waste your money having someone do it, it took me 40 mins the first time and has taken me 20 mins each time thereafter.
http://www.c-speedracing.com go to how to and then valve adjustment.
fwdupree
Jun 1, 2018 12:13 PM
totsie7944
Feb 22, 2009 01:49 PM
Ryan15
Oct 5, 2006 07:00 AM
