tps?
Old Aug 25, 2004 | 09:00 PM
Antilag's Avatar
Default tps?
What do you guys think? its idles from 1000 to 1200 back and forth with a little cough intermittenly. It will not rev past 3000 rpm. and detonates when you try to rev, even with 100 octane fuel and 17 degrees timing.
Their is no cat converter and this is a standalone so it is not in limp mode. Plugs are new and im getting plenty of fuel.
Just wanted to hear your thoughts, I don't have access to a volt meter tonight.
Old Aug 25, 2004 | 09:06 PM
DSRxMilogen's Avatar
Default Re: tps? (9sech22civic)
sorry to steal your thread.. but what does it mean when its in LIMP mode?
Old Aug 25, 2004 | 09:17 PM
AutoWerks's Avatar
Default Re: tps? (xnorxcalx)
what standalone are you running. and what motor setup is it... sounds like you have some tuning issues
Old Aug 25, 2004 | 09:37 PM
Antilag's Avatar
when certain codes are thrown, it will go in limp mode to protect the motor. no vtec and alot lower rev limi.
Old Aug 25, 2004 | 10:10 PM
Antilag's Avatar
just tested it with a voltmeter. o volts at closed throttle and o volts at open throttle with key on car off.
I should get volt readings even though i run a standalone right?
never ran into a tps problem before... lucky me
Old Aug 25, 2004 | 10:12 PM
oh i .. maybe my car is in limp mode cuz it does sounds like it it hits rev limiter and it seems like it has no power at all.. and i'm throwing a code 4.. thanks for the help...hope you can fix your problem
Old Aug 25, 2004 | 10:16 PM
Antilag's Avatar
no problem
Old Aug 26, 2004 | 06:48 AM
Antilag's Avatar
morning bump
Old Aug 26, 2004 | 06:16 PM
AutoWerks's Avatar
should have voltage of .45v with car on and running
Old Aug 27, 2004 | 06:26 AM
Antilag's Avatar
Default Re: tps? (AutoWerks)
I have a FAST harness therefor the wires are different, I had a few very small holes in the exhaust, and the when we got the new fuel pressure regulator, it was set at 45 psi and the car was tuned at 35 therefore it wouldn't rev pass 3000 due to too much fuel, Ohh well off to the dyno today.
Dillon Crumpler
Acura TL, RL & ZDX
Feb 26, 2018 10:02 PM
See Are X
Aug 24, 2005 07:57 PM
See Are X
Aug 22, 2005 08:28 PM
USDM EG
Aug 20, 2005 04:18 AM
Greg456
Jul 23, 2004 11:30 AM
