Valves
Old Jul 23, 2004 | 02:14 PM
Black Z-24's Avatar
Default Valves
A friend recommended to come here for a question, so I figured I would.
I have a 3.1L 12V Cavalier, and I recently took the heads off. I'm almost positive the middle cylinder intake valve isn't opening, but is there any way to check?
I am taking the heads to be machined soon, should I just let them do it?
Thanks
Old Jul 23, 2004 | 03:57 PM
Black Z-24's Avatar
Default Re: Valves (Black Z-24)
bump
Old Jul 23, 2004 | 04:13 PM
non-VTEC's Avatar
how are you positive the intake valve is not opening?
is the push rod bent? lifter collapsed? rocker arm broken?
what your question?
Old Jul 23, 2004 | 06:38 PM
Black Z-24's Avatar
Default Re: Valves (non-VTEC)
The color/shade of that specific intake valve is not the same as the others. Looks identical to the exahust valve.
I first pulled the intake plenum, and when looking into where the intake valve is, there was quite a large puddle of gas. Then, when I pulled the head I saw the discoloration. Heres a picture of the head....
Any thoughts?
Modified by Black Z-24 at 7:51 PM 7/23/2004
Old Jul 23, 2004 | 09:49 PM
EVOCELICA's Avatar
New User
well if it's the same color as the exhaust valve how did it get like that? It had to open to burn something in the cylinder to make it discloroed like the exhaust or could I be wrong
Old Jul 24, 2004 | 02:58 AM
non-VTEC's Avatar
was the engine ticking or making unsusual noises before you took it apart?
Old Jul 24, 2004 | 03:33 AM
Black Z-24's Avatar
No noises. I originally took it apart because there was a coolant/oil mixture and a rear exhaust leak. It was also running very rich, with blue/white smoke burning from the exhaust.
Is there any way to test if it was opening? I would rather not put it on and have to break it all the way back down.
Old Jul 24, 2004 | 09:33 AM
non-VTEC's Avatar
it was probably a bad headgasket on that bank leaking into that cylinder which causes the white/blue smoke and coolant mixing into the engine oil.
if the valve wasnt opening there would be a dead missfire on that cylinder.
have the machine shop check the head surface and even pressure test them to make sure the head is not cracked.
Old Jul 24, 2004 | 11:18 AM
Black Z-24's Avatar
Alright thanks for the help
Free Man
Jun 7, 2018 10:24 PM
sick_dc2
Nov 22, 2008 01:33 AM
hatchy
Feb 25, 2002 11:12 PM
