bearings
Old Dec 27, 2003 | 10:30 AM
djickabod's Avatar
Default bearings
I have a B18a1 Crank and Eagle 4340 H-Beam Rods. I need to know what size or brand Bearings to get.
Old Dec 27, 2003 | 11:19 AM
quik1's Avatar
Default Re: bearings (djickabod)
You should go with the stock color code honda bearings or use ACL bearings.
Old Dec 27, 2003 | 11:23 AM
djickabod's Avatar
Explain the color code please. And would I ask for Main and Rods bearings for a B18a1 from ACL?
Old Dec 27, 2003 | 11:52 AM
quik1's Avatar
Default Re: (djickabod)
There are numbers on your crankshaft, main bearing caps and connecting rods if you have a helms manual those numbers correspond to a color. Since not all of the engines are exactly the same you can get the right bearing by ordering the color that matches the numbers. If you had the journals machined the numbers will not work. That is the best way to do it but since you have eagle rods there won't be any numbers on the rod so you can use the factory rod numbers order those bearings put them on the eagle rods then plastigage them to assure that they are within spec. I have eagle rods on my b18a and I used ACL bearings they are cheaper and some people say that they are better but who knows.
Old Dec 27, 2003 | 12:00 PM
djickabod's Avatar
Thanks alot for the info.
So do you have a site for acl?
Old Dec 27, 2003 | 12:03 PM
3rdGteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djickabod &raquo;</TD></TR><TR><TD CLASS="quote">Thanks alot for the info.
So do you have a site for acl?</TD></TR></TABLE>"Earl" on this sight sells them and so does camp1320.com+ many others. Usually around 99shipped.
Old Dec 27, 2003 | 12:07 PM
quik1's Avatar
Default Re: (3rdGteg)
Try searching on honda-tech there are lots of discussions about them.
Old Dec 27, 2003 | 03:14 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
the eagle rods are supposed to be sized as #3 on the bearing chart. but i would still check your tolerances.
jArceo
Apr 3, 2011 03:01 PM
fxrob
Sep 7, 2004 07:24 AM
douglas_be
Feb 23, 2004 09:17 AM
baonest1
May 31, 2003 04:35 AM
