Eagle rods and bearing?
k, heres the problem, i just called up Eagle today and asked their tech, what kind of bearings they recomend using with their eagle rods, he didn't even ask me what block, he just ask me what make, i told him Honda, then he told me to use OEM number 3 Green bearings, is this guy correct, why number 3 green bearings, if your using eagle rods let me know what kind of bearings are you using.
Solbros Owns Me
Re: Eagle rods and bearing? (EAZY)
just use OEM bearings. That's al I've used with aftermarket rods. What bearings you use depends on if you have to grind the crank or not.
Just be sure and plastigauge first, before final assembly
Re: Eagle rods and bearing? (Emerika)
well the reason i called up Eagle to ask is because i don't have my oem bearings anymore to tell which colors where in there before so i can't plasigauge it to the right bearings, and tried going by the table of colors for choosing bearings with the crank numbers, that thing is confusing, and i took it to my dealer, he doesn't seem so sure so i don't trust him,
i searched and didn't come up with anything, anyone knows of any write up of how to choose OEM bearings colors by the crank numbers and the color table
Re: Eagle rods and bearing? (vtecvoodoo)
anyone in CA, around central valley or bay can help out or knows of any trusty dealers so i can take the crank to
