crx wont start need help!!
Old Apr 4, 2005 | 01:10 PM
P-DuBB's Avatar
Default crx wont start need help!!
having a problem with my crx ....it doesnt start unless i spray carb cleaner ...and when it does start it will it sound like it misfires and it dies out when i step on the throttle and wont rev pass 3000 rpm at full throttle ..my friend said that it might be my distributor....wat do u guys think...need help wanna get back on the road
Old Apr 4, 2005 | 03:20 PM
h22_cx_hatch's Avatar
Default Re: crx wont start need help!! (P-Dubb)
check fuel pump,injectors etc battery, check the distributor everything having to do with ignition and see if there is gas in the fuel tank
Old Apr 6, 2005 | 03:32 PM
P-DuBB's Avatar
Default Re: crx wont start need help!! (h22prludez)
i change the fuel pump, fuel filter, clean out injectors still the same, u think its cuz im not getting enought spark?
Old Apr 8, 2005 | 10:37 PM
P-DuBB's Avatar
sup anyone else need help!!!!!!please
Old Apr 9, 2005 | 11:42 AM
str8boost's Avatar
is the fuel pump priming when you turn on the the ignition??
Old Apr 12, 2005 | 08:44 PM
P-DuBB's Avatar
Default Re: (str8boost)
it sounds like it does but when i took out the fuel injectors, with clips still on ...no fuel shots out......not even when i take the fuel line off......but the pump sounds like it works?.......u think it could be a fuse or a relay?
smileygreasy
15
Apr 19, 2015 07:36 PM
OHrexer
16
Jul 18, 2013 02:29 PM
Built4Battle
Jun 7, 2011 11:49 PM
Projekt CR-X
25
Mar 8, 2011 08:13 PM
mattstru
Apr 26, 2006 05:42 AM
