need help on 89 civic
Old Dec 21, 2005 | 02:41 PM
neuerasd9's Avatar
Default need help on 89 civic
sup guys im new here on the site, and i was wondering if you guys can help me out. i bought an 89civic si without the motor, and the guy had it sitting in his driveway for 2yrs. so i swaped in a 91 integra ls in it. but the the car wont start. it turns over but won't start. i can hear the pump turn on but im not getting any fuel?
can you guys help me out. thanks.
Old Dec 21, 2005 | 10:01 PM
Rukusmasta2's Avatar
Default Re: need help on 89 civic (neuerasd9)
did u do the dpfi to mpfi conversion???
Old Dec 22, 2005 | 10:38 AM
neuerasd9's Avatar
Default Re: need help on 89 civic (Rukusmasta2)
no it has the stock SI wiring on it. the car turns over but wont start. it has spark and everything. i check the fuel line that goes to the fuel filter and it's hella dry, and when i turn on the car there's no fuel going trough it. when i put the key in ignition i can hear the fuel pump turn on for about 2seconds and shutsdown. but still not getting fuel. and i already changed the main relay. and still nothing.
Old Dec 22, 2005 | 09:24 PM
4dohs4mohoes's Avatar
Do you have gas in the car? That would be the first thing I would check. And if so then check to make shure there isnt a clog somewhere. I would think if the car has sat for that long with the lines open, you might have a clog somewhere.
Old Dec 23, 2005 | 09:36 PM
neuerasd9's Avatar
Default Re: need help on 89 civic (boo bees)
yeah man the car have gas, because i added some when i drop in the motor. i will try to change the fuel pump this weekend, i'll let you guys know if it works. thanks..
Old Dec 26, 2005 | 03:31 PM
Well. If you can hear the fuel pump turn on then Its not the pump. Like I said check all the fuel line from the motor to the pump to see if there is a clog somwhere.
Old Jan 6, 2006 | 01:40 PM
neuerasd9's Avatar
i finally got it to start, i changed the fuel pump and it started right up. when i took it out, the filter on the pump was off. maybe that's reason. but thanks for the advice..
Old Jan 7, 2006 | 09:39 PM
edit: Oops, sorry about being wrong. DAMNIT! Good job bro.
turboteg7
Dec 21, 2008 11:12 AM
ludecrasy87
Dec 10, 2006 09:07 PM
GSaargh
Dec 22, 2005 05:32 PM
mikeg015
Jul 9, 2004 07:43 PM
drvfast
May 26, 2004 08:29 PM
