what can cause the speedometer to not work?
92 dx hatch, vx/si cluster forget which (car is at home can't check). is it plug n play? the speedometer doesn't work, milage doesn't go up when driving, needle does not move. what are the possibilities and which one most likely the problem.
Re: what can cause the speedometer to not work? (HmgLauj69)
I'd first replace the speed sensor in the engine bay. Then I'd have someone check all the wires are connected properly to their homes, and are grounded well. I've done all this, and I've been told the only solution is to replace the damn thing with one from a junkyard. This is a common problem with eg civics, so i hear.
if the speed sensor is damaged or the wires not making contact you should get a cel light, check that first
then maybe the fuse
if not the gauge could be damaged
then maybe the fuse
Jvl41291
10-08-2018 02:34 PM
ONEhaque
11-04-2008 06:31 PM
ithinkitsjdm
13
02-23-2005 06:17 AM
