2 questions
Old Apr 19, 2002 | 09:29 AM
Akira-R's Avatar
Default 2 questions
I'm runnig a 2000 JDM ITR with a 99 JDM ITR ECU in a 94 rs with obd1 to odb2 harness.
I'm having a code 14 which is the iacv. I've seen in a previous post where someone said to swap 2 pins in the harness A12 to A14, but that was in a civic dx. Is the same true for the RS? Also my speedo isn't working, and i forgot what someone told me to do about some wire *blue i think* i need to do something with...
I've already got the vtec switch hard wired into the harness and that works fine.
any suggestions?
thnx,
--reid
Old Apr 19, 2002 | 10:12 AM
Spade's Avatar
Default Re: 2 questions (Akira-R)
Replace the IACV. Or take it out and clean it.
Old Apr 27, 2002 | 12:36 AM
Akira-R's Avatar
Just in case anyone is interested what i had to do.
For the RPM, the wire harness for the ls didn't have the rpm wire going into the distributer to the interior harness.
I had to make a wire and run it from the big blue wire on the distributor to the drivers side interior harness plug.
Also had to directly wire the knock sensor to D6 on the ecu for the knock sensor code to not come in. *still in testing*
The IACV hasn't come up since i first started it up, let's see if it comes back.
thnx,
--reid
marks97el
Sep 16, 2008 02:28 PM
hitekper4mance
Oct 9, 2007 08:21 AM
projectegr
Jan 18, 2005 12:32 PM
quiksheit
Mar 29, 2004 06:16 PM
