odometer no work pls help
Old May 12, 2010 | 10:11 AM
96civic808's Avatar
Default odometer no work pls help
only my temp and fuel gauge works.
how to find if my tach/speed meter works?
Old May 12, 2010 | 01:42 PM
lsd96teg's Avatar
Default Re: odometer no work pls help
check your speedo sensor on the transmission
Old May 12, 2010 | 04:05 PM
wtf_is_jdm's Avatar
i wouldnt be so concerned with your odo not working.........its so jdm it will never age..... jk bro. did you check any fuses?
Old May 12, 2010 | 09:57 PM
BiG ChOr!Zo's Avatar
make sure your speedometer cable is hook up properly inside the speed sensor...!!!
Old May 13, 2010 | 02:22 AM
96civic808's Avatar
fuse are all good.
tnx
Old May 13, 2010 | 02:24 AM
96civic808's Avatar
how would i check/test the VSS?
Old May 13, 2010 | 04:26 PM
lsd96teg's Avatar
Well for starters make sure its plugged in lol, and the easiest way to check it is to grab one off a buddies car and swap them to see if it works. Also check your connections on the back of the cluster, just to rule that out.
Old May 13, 2010 | 09:58 PM
96civic808's Avatar
Man I wish one of my buddies has dis car.
Old May 13, 2010 | 10:10 PM
seanbev24's Avatar
How long have you had this problem? Were they working fine before? What work was done in the engine bay and/or the dashboard before they stopped working?
Old May 15, 2010 | 08:11 PM
96civic808's Avatar
i got the car like this.finally pulled out the dash, tested the gauge according to the manual (good). when i took out the gauge,cable was not connected, clip is missing, start the car observe the cable NOT turning.
any ideas? what should i do next?
Old May 15, 2010 | 10:59 PM
96civic808's Avatar
cable suppose to turn Behind the gauge when engine is on correct? The clip is missing can it still work? Any solution? Tnx
Old May 16, 2010 | 08:19 AM
seanbev24's Avatar
You need both retaining clips or it won't work. It's a plastic one on the speedo side, and a little metal one on the tranny side.
Old May 17, 2010 | 11:11 AM
96civic808's Avatar
ok, i got the clip on the tranny side.
where can i get the clip on the gauge side?
Part#?
btw i looked inside the tranny while the engine is on, but the gear inside the tranny is not rotating?
Old May 17, 2010 | 02:45 PM
96civic808's Avatar
what are my other option?
upgrade to electric VSS? how?
i need to know how fast i'm going.
tnx
Old May 17, 2010 | 08:20 PM
seanbev24's Avatar
Part#?
It won't rotate unless the car is moving.
Call Acura, find a da in a wrecking yard, or find someone on craigslist who's parting a da.
Converting to electronic vss requires the sensor and a new cluster, plus custom wiring.
Old May 18, 2010 | 02:27 AM
96civic808's Avatar
hahaha that make sense, sorry i was thinking my tachometer because it also not working.
any idea?
btw tnx for replying man really appreciate it
Old May 18, 2010 | 08:16 AM
seanbev24's Avatar
The tach is electronically controlled with a signal from the distributor. If the previous owner left the speedo cable out, I wouldn't be surprised if the messed up something else behind the cluster.
EgDude
Jun 11, 2008 02:30 PM
rerun07
Dec 8, 2005 08:21 AM
bumpin_bass
Sep 1, 2003 04:19 PM
E Lude U
Aug 1, 2003 10:47 AM
KekeK-18
Apr 27, 2002 12:33 AM
