speedometer??
Old Jan 7, 2003 | 11:23 AM
hitekper4mance's Avatar
Default speedometer??
I don't know if that is how you spell it or not. OH well. I have a 92 Integra to where the needle jumps irratically. What is the problem?? How do you fix it?? THANKS!!!!
Old Jan 7, 2003 | 11:27 AM
SixPAK's Avatar
New User
Default Re: speedometer?? (hitekper4mance)
Haha I have the same problem. Some have told me it's the speed sensor, but that would cause a CEL and I don't have one so it's still a mystery to me.
Old Jan 7, 2003 | 11:36 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: speedometer?? (SixPAK)
I would say its your speed sensor. Thats just my guess..
Old Jan 7, 2003 | 11:46 AM
Default Re: speedometer?? (SIXTYdashONE)
If it doesn't always do it, is it still the speed sensor?? Would it still work occasionally if the unit is bad??
Old Jan 7, 2003 | 02:47 PM
ttt . I need to fix this. ANYONE know for sure!!
Old Jan 7, 2003 | 03:31 PM
Kataku2K3's Avatar
You have an electronic VSS correct... sorry I don't work on 2G Tegs that often but it's 92 so I would think it would be... If so check the tranny ground, a bad motor/tranny ground could cause it to fluctuate irratically... It could be a problem in the VSS but i doubt it... I've never personally seen one go bad but i'm sure that it could happen... If I'm totally wrong and you have a mechanical VSS with a cable driven speedo such as on the older 2G Tegs then I would check the cable... Make sure it still turns freely... If this is the case then perhaps one end has come undone or isn't in tight... (check the end that goes into the VSS itself and where it connects to the back of the cluster) Hope this helps, good luck
Old Jan 7, 2003 | 04:40 PM
Default Re: speedometer?? (Kataku2K3)
Thanks!! That was awesome advice. I'll make sure I check it out or have it checked out.
1992cxcivicEG
14
Jan 5, 2010 01:33 PM
DC2man
Mar 3, 2008 07:01 PM
bg-33p
Feb 12, 2005 10:33 PM
miataguy
Jul 17, 2003 02:25 PM
Mike95lude
Feb 18, 2002 09:50 PM
