my speedo has an attitude problem
Old 01-04-2010, 08:27 AM
1992cxcivicEG's Avatar
Default my speedo has an attitude problem
lol its kinds funny, when im driving the spedo chooses when to work, and bounses all over the place like a kid having a spaz attack. when it spazes out, i watch the trip and it seems to be pretty consistant, would any of the friendly honda-tech fourm fliers help me on where to start on fixing the prob??
Old 01-04-2010, 08:38 AM
EdSales's Avatar
Default Re: my speedo has an attitude problem
Check the VRS (I think thats what its called) that plugs into the Transmission. Make sure its fully in. If it is, may need to replace it. Worst case scernario is getting a new Speedo, but your VRS Sensor is the most likely culprite.
Old 01-04-2010, 10:45 AM
supra-n-civic's Avatar
VSS* its the vehicle speed sensor. several things can go bad with them and this is one of them replace it. most likley it will be on the firewall side of the trannys case standing straight up in the air. it will be held in by a bolt i believe two so dont go ripping at it.
Old 01-04-2010, 10:48 AM
CRXREFIC's Avatar
i remember correctly... three ;p 2 if its just the sensor, three if its the whole entire thing that goes in the tranny
mine was literally chewed up inside
Old 01-04-2010, 04:35 PM
ive checked the trany sensor and it seemed perfect, im stumped
Old 01-04-2010, 04:51 PM
thecruzs2007@yahoo.com's Avatar
try another cluster..i had the very exact same problem..everything else worked except my speedometer..it would only work sometime(hardly) and it would be reading 15 mph when i was in 3rd gear lol and it turned out to be my cluster..works like a charm now good luck
Old 01-04-2010, 05:02 PM
eg_21's Avatar
try another cluster, pull out vss (vehicle speed sensor and clean it thoroughly with brake cleaner, that's what fixed mine up a good clean with brake cleaner.
Old 01-04-2010, 07:34 PM
mhohisel's Avatar
I'd start by checking the VSS. Its either the top part with the connector thats bad (18 bucks on ebay, thats what it ended up being on my sol), or the bottom part with the gear in it.
If the above two fail, then try the cluster, as its the most expensive. ($75-$100)
Old 01-04-2010, 07:36 PM
forcefedferio's Avatar
Mine did the exact same thing, multiple known good VSS's didn't fix it. Replaced speedo (i opted to not replace the whole cluster, just parted out an auto cluster) and it fixed it perfect.
Old 01-04-2010, 07:45 PM
Former User's Avatar
Is it a 92 Civic?
Old 01-04-2010, 08:56 PM
Hanmin's Avatar
If you get water on the sensor, coolant or whatever it'll mess up.
If your car dies out and doesn't want to start again, it'll most likely be because of your icm.
Old 01-05-2010, 10:23 AM
nothing_shocking's Avatar
I had this EXACT problem with mine. Turns out the plug on the wiring harness had some corrosion on it. Cut it off, wired up a new one and it works fine now. Check that before you go spending lots of money.
Old 01-05-2010, 01:25 PM
Originally Posted by RonJ@HT
Is it a 92 Civic?
yes
Old 01-05-2010, 01:26 PM
ok cool thanks guys ill do what u guys said, worst comes to worst im gonna need to buy something lol
Old 01-05-2010, 01:33 PM
Resident Gearhead
BryanM.'s Avatar
Check the VSS sensor and it's connector terminals for corrosion. Very common.
Freckles
08-20-2012 10:30 PM
1Ek 1Eg
01-13-2006 02:14 PM
Polak69pl
01-11-2006 10:14 AM
SPOON_FED_DC_2
07-29-2004 01:13 AM
Mike95lude
02-18-2002 09:50 PM
Quick Reply: my speedo has an attitude problem
