cam timing and dist timing question sohc
Old Apr 18, 2006 | 11:13 PM
cliff666's Avatar
Default cam timing and dist timing question sohc
wats the point of having a cam gear on a sohcvtec? from wat i was told the dizzy is cam driven so isnt that actually adjusting the cam timing also with the ignition timing? just curious because my car's cam gear is adjusted 2 degrees advanced and i was wondering if i will have to adjust it by the cam gear or can i do it by the distributor? just curious and wondering because i just remembered this and tuning is being done tom morning
Old Apr 19, 2006 | 10:49 AM
RaceCarRyne's Avatar
Default Re: cam timing and dist timing question sohc (bruceHungLO)
the dizzy adjusts your total ignition advance and retard.. the cam gear will adjust the cam timing.. aka when the intake and exhaust valves are opening and closing..
cliff666
Apr 18, 2006 11:07 PM
Red_Si
Apr 20, 2004 07:21 PM
Mr.Integra
May 22, 2003 12:41 AM
Alias
Jan 28, 2003 06:56 PM
