Cam Timings Affect on Ignition Timing.
Old Nov 11, 2002 | 02:20 PM
redcxhatch's Avatar
Default Cam Timings Affect on Ignition Timing.
So I retard my cam timing 4 degrees, how does this affect my ignition timing? Does it retard it 8 degrees? Do i change cam timing first, then ingition timing? Thanks.
oh btw its a SOHC if you didnt know.
Old Nov 11, 2002 | 03:01 PM
redcxhatch's Avatar
Default Re: Cam Timings Affect on Ignition Timing. (redcxhatch)
anyone?
Old Nov 11, 2002 | 03:40 PM
Chiovnidca's Avatar
Yes, yes and yes.
Old Nov 11, 2002 | 04:38 PM
RaceTilIDie's Avatar
Default Re: Cam Timings Affect on Ignition Timing. (Chiovnidca)
Each 1 degree of cam rotation is equal to 2 degrees of crank rotation. If your timing is already retarded, and you retard it 8 degrees, it may not idle for you to adjust it so you can either advance ignition timing a few degrees before you adjust the cam gear or adjust a little at a time.
Old Nov 11, 2002 | 11:38 PM
kinesistech's Avatar
Default Re: Cam Timings Affect on Ignition Timing. (RaceTilIDie)
Set the cam timing then reset the ignition timing then test drive/dyno.
Old Nov 15, 2002 | 07:48 PM
redcxhatch's Avatar
Default Re: Cam Timings Affect on Ignition Timing. (kinesistech)
ok, cause for my setup, i want about 4 deg retarded on cam, and 19 deg on ignition, i know i will have to file dizzy holes in order to get to 19, but will my car idle ok? D15B7 w/ D16A6 cam.
Old Nov 15, 2002 | 08:25 PM
Desslok's Avatar
Have you tried different positions for cam gear, mine seems best 2 degrees advanced, retarded lost ALL bottom to mid and made my power band from like 6k - 6500. Also, don't go more than 4 either way, especially if you had head milled, otherwise you may hear the unpleasant "dance of the pistons and valves"
Old Nov 16, 2002 | 08:04 AM
brian b's Avatar
New User
Default Re: Cam Timings Affect on Ignition Timing. (sp)
What if you have a powerfc or something that sets your ignition timing and doesn't use the distributer settings. If you advance the intake cam (dohc) a couple degrees it doesn't do anything to total ignition timing right?
Treyschls
Apr 13, 2023 07:04 AM
Mugen_DC2R
Jun 18, 2007 08:04 AM
donnjuan2point2
Mar 11, 2004 10:49 AM
has-t
Jul 1, 2003 09:58 AM
