Question about cam gear tuning and ignition timing
Old Nov 17, 2001 | 07:42 AM
N1Spec's Avatar
New User
Default Question about cam gear tuning and ignition timing
when you adjust your cam gears does it have to be at TDC? also does the ignition timing change everytime you adjust the cam gears? thanks for helpingn
if anyone could help me with the following problem........ much appreciated ---> https://honda-tech.com/zerothread?id=90595
cheers
Old Nov 17, 2001 | 09:14 AM
non-VTEC's Avatar
Default Re: Question about cam gear tuning and ignition timing (N1 Spec)
when you move the intake cam gear you are also changing the ignition timing since the rotor in the distributor is turned by the intake camshaft. so everytime you make a cam timing adjustment you should adjust the ignition timing as well.
Old Nov 17, 2001 | 02:41 PM
N1Spec's Avatar
New User
Default Re: Question about cam gear tuning and ignition timing (non-VTEC)
thanks....... so when you advance the intake cam your also advancing the ignition timing? i have a feeling the ignition timing is retarded too much
Old Nov 17, 2001 | 07:37 PM
John's Avatar
New User
well, if you need to adjust your ignition timing, the rotate the distributer to advance your ignition timing... loosen the distributer bolts and rotate the distributer towards the firewall... do it in mild increments until you feel that the powerband is what feels appropriate
Old Nov 18, 2001 | 04:58 AM
89civicdx's Avatar
Default Re: Question about cam gear tuning and ignition timing (DunReit)
Buy your self a timing light.
Old Nov 18, 2001 | 05:02 PM
N1Spec's Avatar
New User
Default Re: Question about cam gear tuning and ignition timing (89civicdx)
when installing cam gears, can they be pre-adjusted before installing it? or do they have to be set at 0 then adjusted after the installation?
also what are the consequences of a +10, -10 setting, becos that is what ive done, i didnt adjust the cam gears properly. Any advice?
Old Nov 18, 2001 | 11:15 PM
JR_sohc's Avatar
so u can tune ( adv - ret ) yur motor without messing with the cams? and instead through the distributor?
Treyschls
Apr 13, 2023 07:04 AM
has-t
Jul 1, 2003 09:58 AM
Mr.Integra
May 22, 2003 12:41 AM
redcxhatch
Nov 16, 2002 08:04 AM
iperez
Feb 19, 2002 10:10 AM
