Skunk2 manifold install question????????
Old Mar 19, 2005 | 10:59 AM
shadykit's Avatar
Default Skunk2 manifold install question????????
What sensor goes into this black thing?
Do I need to swap this for Skunk2 manifold? Where does it go?
Old Mar 19, 2005 | 11:13 AM
egsleepercivic's Avatar
looks like the secondary butterfly control for a gsr...not sure though
Old Mar 19, 2005 | 04:56 PM
egizzle8
Guest
Posts: n/a
Default Re: (egsleepercivic)
Evap?
Old Mar 19, 2005 | 06:00 PM
sander's Avatar
2.7(p/t)
IAB vaccum can. Remove that vaccum can.
-s
Old Mar 20, 2005 | 10:34 AM
shadykit's Avatar
Default Re: (sander)
So remove the IAB vacuum can? what about the hoses?
Old Mar 20, 2005 | 11:01 AM
turtle-eg's Avatar
Default Re: Skunk2 manifold install question???????? (kitchale)
The vacuum box is for the secondarys in the stock gsr manifold, take out the vacuum box, don't need the vacuum hose to it either... you might have to leave the vacuum solenoid from the box hooked up to the harness or if might throw a check engine light(not sure though).
The second picture is for the evap, you can hook it up or leave it out, but since you're OBD2, if you don't hook up the vacuum hose, it'll throw a light. Just hook it up to one of the 1/2" ports coming from the manifold.
Btw, what throttle body and throttle cable are you using?
Old Mar 20, 2005 | 11:12 AM
shadykit's Avatar
Default Re: Skunk2 manifold install question???????? (turtle-eg)
I am using the gsr tb and cables for now.
Old Mar 20, 2005 | 11:13 AM
shadykit's Avatar
What about the senor on the IAB? don't plug that in too?
Old Mar 22, 2005 | 01:44 PM
integrator43's Avatar
you no longer need the resevoir, solenoid or hoses. you do need the purge control solenoid.
civics4lyfe
Jun 7, 2015 12:44 PM
dx2sicrx
May 29, 2008 08:20 PM
z6
Jun 14, 2004 03:01 PM
Adriano
Jun 22, 2003 06:35 PM
c1civic
Sep 5, 2002 09:38 PM
