IM install ??
Old Jun 22, 2003 | 05:35 PM
Adriano's Avatar
Default IM install ??
I just got a JG edelbrock IM for my turbo gsr. Under the stock manifold, there was a black bottle attached to the manifold. It has some vacuum hoses hook up to it. One the hose goes to the side of the manifold too a sensor (it' round and kind of flat metal piece that has some springs attached to the manifold). On the new manifold, i didn't find a place to hook it up. what do i do about it. Im gonna try to find some pic to make things clearer. Thanks
Old Jun 22, 2003 | 05:39 PM
Flamenco-T's Avatar
Default Re: IM install ?? (brryder)
just take out the black box, it is the IAB box to control the secondary on the GS-R IM, but since you;re running a single runner, you won;t need it
stan
Old Jun 22, 2003 | 05:43 PM
Adriano's Avatar
Default Re: IM install ?? (Flamenco-T)
ok, but i have a vaccum hose hook up to it coming from my FPR. Can i just hook up the hose to another boost or vaccum source. Thanks
Old Jun 22, 2003 | 05:47 PM
Flamenco-T's Avatar
yes, just re-route the vac line for the FPR to other sources
stan
Old Jun 22, 2003 | 05:48 PM
Adriano's Avatar
Thanks a lot
Old Jun 22, 2003 | 06:25 PM
bottlefedb18c1's Avatar
like said above that box is not needed when you change to a single runner manifold i forgot to tell you that when you picked it up that day
and what lines are you needing ??
Old Jun 22, 2003 | 06:31 PM
Adriano's Avatar
Default Re: (bottlefedb18c1)
My aem fpr wont fit the manifold. The fuel hose gets in the way. Will there be a problem if i flip it 180 degrees? This way, the fuel return line will be pointing up instead of straight down. I have to get a longer fuel hose for than and i broke one of the coolant hose when removing it. Hopely i will finish it tomorow after work. Thanks
Old Jun 22, 2003 | 06:35 PM
Default Re: (brryder)
ya i mentioned about flipping the fpr that what i had to do and get a barb fitting and a peice of fuel line at a auto parts shop make shure that you get a brass barb fitting so you can put the two peices together
shadykit
Mar 22, 2005 01:44 PM
crexer
Mar 19, 2005 08:27 AM
Nextelbuddy
Mar 26, 2004 05:08 PM
youngvedder
Jan 3, 2003 03:24 AM
