Setting timing?
Old Mar 15, 2007 | 05:51 PM
boomersz's Avatar
Default Setting timing?
trying to set my timing to stock 16º on my gsr but im getting mixed answers. does it need to be at the white or red on the crank pulley?
also on cspeeds site it shows theres 3 colors but i only see white and red no green?
Old Mar 15, 2007 | 07:25 PM
egsleepercivic's Avatar
if you use a light that is adjustable use the white mark, if using a non adjustable light use the red mark.
Old Mar 15, 2007 | 07:27 PM
boomersz's Avatar
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">if you use a light that is adjustable use the white mark, if using a non adjustable light use the red mark.</TD></TR></TABLE>
im using this gun http://www.sears.com/sr/javasr...23000
i have the gun set at 16º and can only see the red and white marks. some one said that the paint might be rubbed off
Old Mar 15, 2007 | 07:52 PM
just align it with the white mark to the pointer, and gun set to 16* and you should be set, don't forget to jump the service connector
Old Mar 15, 2007 | 07:57 PM
boomersz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">just align it with the white mark to the pointer, and gun set to 16* and you should be set, don't forget to jump the service connector</TD></TR></TABLE>
yeah i jumped it whenever i tried set the timing.
ok so i looked and the red is in the middle of the group of 3 and the white is still where it supposed to be, like an inch away from the others.
so with the adjustable timing light, i can just line up the white one to the marking on the cover and set the light to 16º and it'll be good?
Old Mar 17, 2007 | 05:27 PM
bright rider's Avatar
i was wondering the same thing when i was installing a timing belt , so when i set up my cam timing i should be using the 0btc marked lined up with the pointer on the block
and
ignition timing should be set at 16btc with a timing light with the service jumper bridged
Old Mar 18, 2007 | 08:22 AM
standbackimapro's Avatar
You have to also jump the service connecter on the ECU, or else when you change the timing the cars computer will reset it...
Old Mar 18, 2007 | 01:09 PM
service connector on the ecu - 2 pin blue connector below the passengers footwell.?!
Old Mar 18, 2007 | 01:51 PM
Yah, U gotta jump it with a paper clip or somthing
Old Mar 19, 2007 | 01:40 PM
ok , and the cambelt side , the obtc has to line up against the mark on the lower timing cover right ..!"
RACING INTEGRATION
Nov 22, 2008 09:02 AM
boomersz
Mar 16, 2007 10:36 AM
DoubleO6point9
Nov 10, 2003 04:12 AM
allmotor.net
Nov 8, 2002 08:45 AM
Spoon Si
Sep 8, 2002 11:17 AM
