Which mark on Pulley for TDC...
Old Nov 7, 2003 | 09:50 PM
DoubleO6point9's Avatar
Default Which mark on Pulley for TDC...
Alright, having some timing issues with my car and i'm pretty sure it's retarded(can't check because the timing gun just crapped out) because my cousin used the wrong marking on the pulley to set TDC. My cousin used the very last white marking to set TDC and I thought(its been awhile since i've last done this) that you're supposed to use the middle red mark out of the three that are grouped together for TDC. Which is the right one?
Old Nov 7, 2003 | 09:54 PM
sleepN's Avatar
The white mark by itself is the TDC mark. The other three are ignition timing ( BTDC if i remember correctly)
mel_2kgsr's Avatar
Default Re: Which mark on Pulley for TDC... (DoubleO6point9)
it is the white marker that is used for setting the timing
Old Nov 7, 2003 | 09:59 PM
Default Re: Which mark on Pulley for TDC... (mel)
Ok, thanks guys..Just double checking.
Old Nov 10, 2003 | 04:12 AM
JimBlake's Avatar
Use the white mark off by itself for setting the camshaft sprockets.
When you set the spark timing, you use the red mark (middle of 3) if your timing light doesn't have an advance dial.
Or if your light has an advance dial, set it to 16 or 18 or whatever, then use the white TDC mark.
Chickomenon
Oct 29, 2004 09:43 AM
handa
13
Jul 31, 2004 05:19 PM
jdurston
Jun 9, 2004 05:30 AM
civicracer1993
Jan 3, 2004 10:54 AM
StlSupra
32
Oct 21, 2003 10:11 AM
