?'s on block assembly
Old Jul 18, 2010 | 06:49 PM
bakomack's Avatar
Default ?'s on block assembly
I have a spare gsr block I wanna assemble and im not sure about a few things.
I want to throw a ls crank, ls rods, and oem pct pistons into it. standard bore.
will this work? will the piston rise above the deck? what compression would I be at using a b16 head with flat faced high comp valves and 3 ply head gasket.
thanks for the help guys
Old Jul 18, 2010 | 07:11 PM
xrated1's Avatar
Default Re: ?'s on block assembly
No, but you are going to need delete plugs and better pistons because you are going to take out the oil squirters and it is to lube the pistion better. With after market you can get away with that.
Old Jul 18, 2010 | 07:13 PM
bakomack's Avatar
your right I forgot about that. ok what about if I just awapped the stock gsr pistons for the pct pistons and left the stock gsr rods snd crank in there?
Old Jul 18, 2010 | 07:35 PM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
your compression is going to be 12.98 to 1 with those pistons and you can run the squirter, they help with cooling also.
http://www.zealautowerks.com/ go here to check your compression
Old Jul 18, 2010 | 10:46 PM
xtremescouts's Avatar
you can run the squirters with a ls crank if your willing to do a little work. You first need to grind the bolts that hold the squirters in place. you need to grind off enough to clear the crank counterweights and make sure to leave a little extra room between the bolt and crank for expansion. Also after this is done you need to bend the nozzle on the squirter carefully out of the way of the counter weight. You need to make sure it is still facing towards the wrist pin area though and take great care when bending this as it will kink easily. I had done all of this in my old car and it worked flawlessly for the whole time it was in my possesion and as far as i know is still works today and this was years ago now.
a little time and a little work is well worth keeping them as they are good to have for cooling and lubrication purposes.
hope this helps and wish i had pictures of this but this is all i have so if you have any questions please let me know.
sleepencivic
Oct 21, 2010 08:57 AM
dc4teg95
Nov 3, 2007 03:49 PM
B16Drag
Jun 17, 2005 04:23 PM
RAWB
Mar 23, 2003 03:51 PM
B18C1_T
Nov 19, 2002 01:20 PM
