Need help with ECU Error code.
Is it possible to fool the ECU into thinking the NB O2 heater is working ?
Im not talking about chiping the ECU and turning it off.
Rather want to run a 1 wire o2 setup or a WB with NB o2 out and just disable the heater error code.
So would putting a resistor between the o2 heater wires solve the problem ?
Need to read a 4 wire O2 data sheet.
Ok answering my own question found this
http://highlanderclub.ru/files/manua...4h/cip0037.pdf
frog169
Dec 12, 2005 08:13 PM
civicdragger818
10
Jun 23, 2003 11:51 PM
